Bandwidth for VoIP H323 signaling channels
Hallo
I have a VoIp application between two LANs connected by FR WAN.
I use two cisco1751 routers as gateway.
I would use LLQ and other QoS features on cisco gateway to prioritise VoIP streams.
access-list 100 permit udp host 192.168.1.1 host 192.168.2.2 range 16384 32767
access-list 101 permit tcp host 192.168.1.1 host 192.168.2.2 eq 1720
class-map voip-media
match access-group 100
exit
class-map voip-signaling
match access-group 101
exit
policy-map qos-voip
class voip-media
priority 12 (* number of VoIP channels)
class voip-signaling
bandwidth XXX
class class-default
fair-queue
Using g.729a codec and vad.....I would reserve 12kbps for each VoIp media channel (RTP) in the strict priority queue.
How many bandwith must I give to VoIP signaling (RTCP, H225) for each voIp channel ?
thankyou
Re: Bandwidth for VoIP H323 signaling channels
With G.729 codec & Voice payload of 40 bytes, VAD, cRTP, FRF12, you need 6.3kbps bandwidth.
Here is the excellant url which talks about Per Call Bandwidth Consumption for VoIP calls for different media.
http://www.cisco.com/warp/public/788/pkt-voice-general/bwidth_consume.html
Based on that you can do the math for the bandwidth required.
Also here is the url which talks about QoS over Frame-relay for VoIP calls
http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/qossol/qosvoip.htm#xtocid36
Tejas:
I have a similar problem, I have voice over IP running over frame relay between a 7500 & a 3600 router. Doing DTS on the 7500 side. Everything works fine but when I try to use rtp compression to save some bandwith..it seems like "even though the command for rtp header-compresion are accepted on the interface configuration" Compression is actually not happening. Monitoring through EMCOM..sindle takes about 32K..i am suspecting that due to DTS on 7500 side..I am missing something....
Is there any good url ..you can suggest me....As far as enabling rtp header compression is concerned it is very straight forward...the requirement is that ditsributed CEF be enabled globally & interface level which I am already doing...
regards
I too have observed similiar problem as above when I was using different series of routers.But when I connected 1751 routers at both sides with rtp compression, the compression is successful.
605
