Basic Qos question & shaping
we have a corp office with 20mb EFM connection into an MPLS network.
We have 100+ remote offices, some using the same size EFM pipe and others using VDSL @ 80/20mb & ADSL 20/2.5mb to 8/1.2mb.
Now they are all hitting the corp office and we're suffering from choppy, robotic, underwater sounding voices which is sporadic but only when it traverses the MPLS network which has QoS enabled
I suspect that we need to traffic shape on the corp & branch office outgoing and prioritise VoIP on these.
Also to police the incoming on the corp office.
Does anybody have any idea what sort of limits I should be setting for the shaping and policing eg I don't think outgoing at the branch office shape should be set to 20mb (corp office limit) but reduced to a limit where it's probably unlikely that all branch offices will reach 20mb agregate outgoing at once.
Anyone?
Super Bronze
Re: Basic Qos question & shaping
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Does your MPLS cloud support QoS?  If not from what you describe, you want it to do so.
If your MPLS cloud supports QoS, and you're using it correctly, then what you need to do is manage any bottleneck to the cloud.  For interfaces where there's a logical cap less than the physical interface, you'll want to shape to the logical cap.
To add to what Joseph said.  After identifying your cloud (provider) support QOS, you want to know what they are marking at so you can use that into the cloud.  Most times good carriers will make available their markings on the accesable customer sites or require you contact them for this information.
1. Confirm MPLS cloud supports QOS.
2. Mark traffic into cloud with markings supported in cloud for your varous traffic types.
3. Confirm your MPLS cloud trust your markings.  The carrier might require an additional charge to this (not free most times).
4. Analyze your traffic to know how to further fine tune traffic for desired results.  Remember your voice traffic is not the only traffic types you have.
621
