Dear All ,
I have one Voice Gateway cisco 3800 and call manager 7 . i want to block all incoming Call from outside to EXT :111, 222 , 333 and make this EXTs available just internal or inside the CLUSTER . i tried to use translation profile on the Voice Gateway . But, there is something missing can anyone help in this case . the configuration on the Voice Gateway i used it as following :
voice transltion-rule 1
rule 1 reject /^111$/
rule 2 reject /^222$/
rule 3 reject /^333$/
voice translation-profile call_block
translate called 1
dial-peer voice 1 voip
call-block translation-profile incoming call_block
call-block disconnect-cause incoming call-reject
i will be
thankful for any help toaccomplish this
