Call Counters
Dear NetPros,
We have configured a Cisco AS5350 for terminating originating traffic. This voice gateway is connected to 4 E1s which are E1 R2 CAS. I have configured preference on the dial-peers in such a way that the first E1 has 1st preference, second E1 has 2nd preference and so on. The issues that we are facing are these:
a] On our first E1 the DS0s Active High Water
Mark has never crossed more than 24 though we
have an E1s connected to the gateway. Also
when we see the call resource voice stats it
shows the Addressable Channels under DS0
Statistics as 120 [for 4 E1s].
b] If we have given the first preference to the
1st E1, second preference to the 2nd E1 and so
on then why are the calls going to the second
E1 even before the first E1 is getting filled
up i.e. why are the calls going to the second
E1 even before the active DS0s on the first E1
reach 30.
The Output of the E1 Call Counters are given below for analysis:
E1 3/0:
DS0's Active: 23
DS0's Active High Water Mark: 23
TimeSlot Type TotalCalls TotalDuration
1 cas 27 06:56:03
2 cas 22 07:16:33
3 cas 31 05:12:04
4 cas 24 06:30:35
5 cas 31 06:44:21
6 cas 22 06:36:16
7 cas 29 05:14:18
8 cas 25 07:00:22
9 cas 34 06:38:56
10 cas 32 06:03:33
11 cas 31 06:44:28
12 cas 23 08:24:29
13 cas 26 07:03:44
14 cas 30 05:31:09
15 cas 24 08:50:40
17 cas 28 06:36:15
18 cas 27 07:10:57
19 cas 26 06:00:21
20 cas 24 06:38:43
21 cas 30 05:07:44
22 cas 27 06:31:40
23 cas 28 07:38:50
24 cas 21 07:03:18
25 cas 28 06:40:47
26 cas 22 06:26:13
27 cas 25 06:40:32
28 cas 26 07:15:15
29 cas 22 06:16:50
30 cas 21 07:20:05
31 cas 25 07:07:51
Total DS0's Active High Water Mark: 23
Total Calls since System Bootup: 60716
E1 3/1:
DS0's Active: 0
DS0's Active High Water Mark: 1
1 cas 0 00:00:00
2 cas 0 00:00:00
3 cas 0 00:00:00
4 cas 0 00:00:00
5 cas 0 00:00:00
6 cas 0 00:00:00
7 cas 0 00:00:00
8 cas 0 00:00:00
9 cas 0 00:00:00
10 cas 0 00:00:00
11 cas 0 00:00:00
12 cas 0 00:00:00
13 cas 1 00:00:32
14 cas 0 00:00:00
15 cas 0 00:00:00
17 cas 0 00:00:00
18 cas 0 00:00:00
19 cas 0 00:00:00
20 cas 0 00:00:00
21 cas 0 00:00:00
22 cas 0 00:00:00
23 cas 0 00:00:00
24 cas 0 00:00:00
25 cas 0 00:00:00
26 cas 0 00:00:00
27 cas 0 00:00:00
28 cas 0 00:00:00
29 cas 0 00:00:00
30 cas 0 00:00:00
31 cas 0 00:00:00
Thanx
Rushabh
Re: Call Counters
This stement is kind of confusing: "AS5350 for terminating originating traffic"
If the 5350 is terminating traffic only, then the priority of the E1s will not make any different , it would be up to the telco sending you the calls to choose which E1 they will send the calls on.
If this is originating traffis, then I would expect it to work as you described.
Hope this helps....
Re: Call Counters
Yes it is only terminating traffic which is coming from Tier 1 Carriers around the world.
Re: Call Counters
OK, then the switch that you connected to will determine which E1 the calls will be sent to you on.
You could ask them to round-robin between the E1s.
Hope this helps....
147
