Community Member
call dispatch
I have one T1 circuit for TDM voice traffic. It supports in/out (can recevie call from provider and send the call to providers). How do I send the call to provider always from channel 23rd? how to config the routers?
Rgds
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: call dispatch
Usually providers send calls on the lowest channel. You can check that with "debug isdn q931".
However the ISDN protocol is made so that call will never collide, so you don't have to worry about.
Re: call dispatch
Hi, by default, the router sends outgoing calls from the highest channels in descending order. So, there's nothing to configure.
Community Member
Re: call dispatch
if so, the provider sends us the call via highest channels. does it have problem? (in bound call and outbound call go to the same channel). how to avoid it?
rgds
Re: call dispatch
176
