Configuring Call Forwarding
You can configure Cisco SPS to perform call forwarding, providing that you have a MySQL database.
**** For call forwarding, you need to define the corresponding subscribers. Rather than editing an existing subscriber, add a new one:
user --> 5100
domain --> cisco.com
Then add a call-forwarding URL for that user. Enable the corresponding call-forwarding feature in sipd.conf as well.
These are the step needed please follow exactly:
******Step 1: In the (Linux) /usr/local/sip/conf/ or (Solaris) /opt/sip/conf directory, open the sipd.conf file using a text editor such as vi:
# vi sipd.conf
*********Step 2: Set the following directives as needed:
CallForwardUnconditionalForwards calls unconditionally. Valid values are On (forward) and Off (do not forward).
CallForwardNoAnswerForwards calls when a call is not answered within a designated amount of time. Valid values are On (forward) and Off (do not forward).
******Step 3 : Save and close the file.
