Call forwarding Issue with CME
dtaglieri
I have a Call Manager Express system version 3.2 router 2811. When I dial long distance everything works fine but if I forward a call to a long distance number I recieve dead air and see the following error in my debugs
Cause i = 0x82FF - Interworking error; unspecified
> Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have
> in-band info
> *Mar 10 18:45:18.579: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8
> callref = 0x0002
Anyone see this issue or know what this error means? I can forward calls to external local numbers and the local CO says it sees 11 digits coming across and pointed to AT&T.
ebreniz
Level 6
Level 6
The cause code says problem with local telco.
Check the codecs too.
http://www.cisco.com/warp/public/129/isdn_disc_code.html
tlienskt
I also have this same issue. Have you found the fix yet??
