call forwarding on qsig
Hi I am having a problem with forwarding a phone to voice mail over leased line.I have 2 2600's each with qsig connection to pbx.when a phone is forwarded over the leased line from one end to the other it only works 50% of the time ie. when it doesn't work it seems the phone just rings out and never goes to voicemail.I have looked at q931 debugs and for a good and bad call both debugs look identical.Also when there is success I notice that more than 1 isdn channel is being brought up.For it to work it seems to need 4 channels which seems crazy.My signaling config is as follows.interface Serial1/0:15
no ip address
no logging event link-status
isdn switch-type primary-qsig
isdn protocol-emulate network
isdn incoming-voice voice
isdn bchan-number-order ascending
fair-queue 64 256 0
no cdp enable
is there any tweeking I can do to rectify this situation or is there an inherant problem with the amount of channels being seen as busy by the pbx for a successful forwarding to voicemail?Another thing is that it works every time when calling the ddi number which is forwarded over leased line to voicemail.Any opinions appreciated thanks!
  • Voice over IP
Re: call forwarding on qsig
Can you get a debug ISDN q931 for the same call from both routers for the same call please.
The Cisco router should pass this information in a Facility Message over the network. So if this message is the same at both ends then you need to get the PABX engineers involved.
Colin
Hi thanks for taking a look. Here are the debugs you asked for.They aren't totally complete but the bit you want should be in there.
4w1d: Bearer Capability i = 0x8090A3
4w1d: Channel ID i = 0xA98381
4w1d: Calling Party Number i = 0x49, 0x80, '545', Plan:Private, Type:Subscriber(local)
4w1d: Called Party Number i = 0x80, '567', Plan:Unknown, Type:Unknown
4w1d: ISDN Se1/0:15: RX <- CALL_PROC pd = 8 callref = 0x8C54
4w1d: ISDN Se1/0:15: RX <- ALERTING pd = 8 callref = 0x8C54
4w1d: Facility i = 0x9FAA068001008201008B0100A124020207B4020101301B8400A51706052B0C024E01300E8004313238380A01040403353637
4w1d: ISDN Se1/0:15: RX <- FACILITY pd = 8 callref = 0x8C54
4w1d: Facility i = 0x9FAA068001008201008B0100A124020207B506052B0C024E0130178004313131310A0105040C2A3230332A42452A35343623
4w1d: Facility i = 0x9FAA068001008201008B0102A137020207B6020113302E0A010330058003353436020101400504038090A3A108A006800431323334820102A4028100A607A0058003353637
4w2d: ISDN Se1/0:15: RX <- SETUP pd = 8 callref = 0x0025
4w2d: Bearer Capability i = 0x8090A3
4w2d: Channel ID i = 0xA98381
4w2d: Calling Party Number i = 0x49, 0x80, '545', Plan:Private, Type:Subscriber(local)
4w2d: Called Party Number i = 0x80, '567', Plan:Unknown, Type:Unknown
4w2d: ISDN Se1/0:15: TX -> CALL_PROC pd = 8 callref = 0x8025
4w2d: ISDN Se1/0:15: TX -> ALERTING pd = 8 callref = 0x8025
4w2d: Facility i = 0x9FAA068001008201008B0100A124020207B4020101301B8400A51706052B0C024E01300E8004313238380A01040403353637
4w2d: Progress Ind i = 0x8188 - In-band info or appropriate now available
4w2d: ISDN Se1/0:15: TX -> FACILITY pd = 8 callref = 0x8025
4w2d: Facility i = 0x9FAA068001008201008B0100A124020207B506052B0C024E0130178004313131310A0105040C2A3230332A42452A35343623
4w2d: Facility i = 0x9FAA068001008201008B0102A137020207B6020113302E0A010330058003353436020101400504038090A3A108A006800431323334820102A4028100A607A0058003353637
4w2d: ISDN Se1/0:15: RX <- FACILITY pd = 8 callref = 0x0025
4w2d: Facility i = 0x9FAA06800100820100A20B020207B630050201130500
4w2d: ISDN Se1/0:15: RX <- DISCONNECT pd = 8 callref = 0x0025
4w2d: Cause i = 0x8090 - Normal call clearing
4w2d: ISDN Se1/0:15: TX -> RELEASE pd = 8 callref = 0x8025
4w2d: ISDN Se1/0:15: RX <- RELEASE_COMP pd = 8 callref = 0x0025~
146
