Community Member
call waiting on 7910 phone
Does the call waiting feature work with a 7910 phone? If so how?
Silver
Re: call waiting on 7910 phone
The Call Waiting feature is enabled very similarly to your phone at home where as you flash the hook in order to accept the 2nd call. Also like your phone at the house you can switch back and forth between lines by flashing the hook repeatedly (ie using the hold button on the phone)
Community Member
Makes sense. I didn't even think to try that. Thanks.
165
