Call waiting to be disabled in ATA 186
We have a setup of a central 2610 Router acting as Gatekeeper and remote 805 Routers.The setup is working fine but the problem is when a conversation is going on if another person calls up he is not getting the busy tone but he also gets the ring tone which is causing the problem.We need to disable call waitng in the ATA so that only one call will mature and it will give a busy tone for the second call.Can anyone suggest on how to disable the call waiting in the ATA.
1 REPLY
Silver
Re: Call waiting to be disabled in ATA 186
You will have to manually configure this under configurable tones ,where you get call waiting tone. For the suitable values and Advanced configuration refer this manual
http://www.cisco.com/univercd/cc/td/doc/product/voice/ata/ataadmn/ata88sip/sip88.pdf
206
