Caller name/ID on incoming MGCP Gateway
Where do you apply parameter setting changes to allow not only Caller number but name as well to come through on a MGCP VG? What parameters in CCM 4.1 should be checked? Isn't caller-ID needed on the dial-peer as well. Sprint is the carrier.
Thanks for any guidance
Re: Caller name/ID on incoming MGCP Gateway
What type of PSTN circuit is this?
If its an FXO port, caller-id is not supported in MGCP.
If its a PRI, how is calling name being delivered? Display IE or facility IE? A "debug isdn q931" for an inbound call will show you this.
It is being delivered via: Display i = 'Voicemail' as taken out of q931 debug. So is there a parameter in CCM that needs to be set? or on the VG itself?
Thanks.!
248
