calls are breaking
we are using MGCP/RTP in our voice network, from few days customers complaing about quality of the calls and calls are breaking, we did few test but couldnt figure out whats a problem.
thanks
asim
Bronze
Re: calls are breaking
Hi Asim,
Please make sure that you have qos configured for voice. For voice, it is recommended that you use LLQ. Here is a document that has sample config of LLQ.
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a0080101210.shtml
HTH,
Tony
Bronze
Do the following. Whenever you get bad quality call, press ? (info button) twice on the IP phone. If you see a lot of dropped packets you likely have QoS issue. If you don't see dropped packets you might have issue with PSTN interface (PRI, R2, FXO, etc.)
Bronze
Dropped packets means that your RTP packets are getting lost somewhere between the 2 endpoints. I could only see it being a qos issue if you have qos configured and the amount of VOIP rtp traffic is exceeding what you have configured in the priority queue. Otherwise, you may need to explore where the packet loss is occurring, whether it be on the WAN or LAN.
286
