Calls from PSTN to IP phones fail
Software Version: ccm 3.3.2, vg200 12.2.11
Calls from the PSTN (PRI line) will come in and will only ring once and the call will end. Seconds later the same call will come in and ends after one
ring. This will repeat up to five times.
2nd PRI addeded to vg200 (12.2.11t) using vwic2mt module. Phone provider has been monitoring trunk lines They show 14 failures after the call leaves their switch.
I have checked the T310 timer in CCM and is set to the default 60000msec.
A deub on the VG200 shows the following:
Apr 6 15:23:15.332: ISDN Se1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x18D2
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98391
Exclusive, Channel 17
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = '!', 0x83, '6237642292'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '5678'
Plan:Unknown, Type:Unknown
Apr 6 15:23:15.356: MGCP Packet received from 10.10.xxxxxx-
CRCX 827582 S1/DS1-0/17@MAIN_VG200xxxx MGCP 0.1
C: D0000000010a268700000000800018d2
L: p:20, a:PCMU, s:off
M: recvonly
Apr 6 15:23:15.368: send_mgcp_msg, MGCP Packet sent to 10.10.xxxxxxx--->
Apr 6 15:23:15.368: 400 827582 Voice call setup failed
Apr 6 15:23:16.388: MGCP Packet received from 10.10.xxxxxx-
CRCX 837582 S1/DS1-0/17@MAIN_VG200xxxx MGCP 0.1
M: recvonly
Apr 6 15:23:16.404: send_mgcp_msg, MGCP Packet sent to 10.10.xxxxxx--->
Apr 6 15:23:16.404: 400 837582 Voice call setup failed
Apr 6 15:23:16.404: MGCP Packet received from 10.10.xxxxxx-
DLCX 827583 S1/DS1-0/17@MAIN_VG200xxxxx MGCP 0.1
X: 11
S:
Apr 6 15:23:16.412: send_mgcp_msg, MGCP Packet sent to 10.10.xxxxxx--->
Apr 6 15:23:16.412: 250 827583 already deleted connection
Apr 6 15:23:19.333: ISDN Se1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x18D2
Standard = CCITT
Apr 6 15:23:19.353: MGCP Packet received from 10.10.xxxxxx-
CRCX 827584 S1/DS1-0/17@MAIN_VG200xxxx MGCP 0.1
C: D0000000010a268900000000800018d2
M: recvonly
Apr 6 15:23:19.369: send_mgcp_msg, MGCP Packet sent to 10.10.xxxxxx--->
Apr 6 15:23:19.369: 400 827584 Voice call setup failed
Apr 6 15:23:20.389: MGCP Packet received from 10.10.220.20-
CRCX 837584 S1/DS1-0/17@MAIN_VG200xxxxxx MGCP 0.1
M: recvonly
Apr 6 15:23:20.401: send_mgcp_msg, MGCP Packet sent to 10.10.xxxxxx--->
Apr 6 15:23:20.405: 400 837584 Voice call setup failed
Apr 6 15:23:20.405: MGCP Packet received from 10.10.220.20-
DLCX 827585 S1/DS1-0/17@MAIN_VG200xxxx MGCP 0.1
X: 11
S:
Apr 6 15:23:20.413: send_mgcp_msg, MGCP Packet sent to 10.10.xxxxxx--->
Apr 6 15:23:20.413: 250 827585 already deleted connection
Apr 6 15:23:23.381: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x18D2
Cause i = 0x80E6 - Recovery on timer expiry
Apr 6 15:23:23.981: MGCP Packet received from 10.10.xxxxxx-
MDCX 827586 S1/DS1-0/21@MAIN_VG200xxxx MGCP 0.1
C: D0000000010a26690000000080000ca7
I: 1636
X: 15
M: recvonly
R: D/[0-9ABCD*#]
Q: process,loop
1 REPLY
Re: Calls from PSTN to IP phones fail
Tracy,
It is hard to say what is going on here but the telco switch is dropping the call becasue we never sent a call proceeding or alerting message back to it. This is not a problem with the T310 timer in CallManager.
On the surface, it looks as if the problem is on the VG200 because CallManager has instructed it to reserve the timeslot for a call via the CRCX, but the gateway is the one that rejects it with a 400 error message which means there was some condition on the gateway that prevented it from setting up the call.
What is the status of the T1? Are there channels that are busied out.
At any rate to get further insight, you would probably need to run the following debug on the gateway to get a sense for why the gateway is having problems processing the call setup
debug vpm signal
debug vtsp all
That would be a starting point.
hth
Ademola
203
