08-27-2008 09:31 PM
I have an issue where we need to transcode g711ulaw to g711alaw between voip providers using SIP
I would like to know if it is possible to use an AS5350 for such a task?
Any links or references to what I would need to do in the configuration would also be greatly appreciated.
08-28-2008 03:12 AM
i am not sure if u have DSPs for this !
09-09-2008 02:24 AM
Yes, this can be done by using AS5350 as CUBE.
Please go through the documentation:
Make sure below is configured with proper dial-peers.
voice service voip
allow-connections sip to sip
dial-peer voice 100 voip
incoming called-number 919.......
codec transparent
dial-peer voice 200 voip
destination-pattern 919........
codec g711alaw
Below is for your reference.
Cisco UBE on Cisco.com
Cisco CommunicationsTransformations Whitepapers
http://www.cisco.com/go/cube(section of Whitepapers)
Customer Case Studies
Cisco Networkers Presentations
SIP Trunks for PSTN
CUBE Designs
Cisco UBE PBX Interoperability Reports (Avaya / Nortel)
