Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CCME Installation issue
HI
im trying to install a fresh CCME
but when im trying to extract both CCME and GUI files im getting this error.
CCME# archive tar /xtract tftp://192.168.13.26/cme-gui-4.1.0.1.tar flash:
%Error, "tftp://192.168.13.26/cme-gui-4.1.0.1.tar" is a directory.
i tried formatting flash and all things.
still im not able to install
please reply
Many Thanks
Manoj
Hall of Fame Super Gold
Re: CCME Installation issue
yes, it is a know bug.
Try
ftp://:@ftp.cisco.com/cisco/voice/ip-phone/ip-iostsp/cme-gui-4.0.3.1.tar
If still problems, upgrade IOS image.
hope this helps, please rate post if it does!
Silver
This is not a bug, you are using an invalid syntax:
Try 'archive tar /x tftp://192.168.13.26//cme-gui-4.1.0.1.tar flash:'
Note the double forward slash '//' after the ip.
This is clearly documented.
It's definately a bug - CSCek63178
Symptom:
When extracting a .tar file via the command line from a tftp or ftp server
the following error may occur:
Router#archive tar /xtract ftp://X.X.X.X/XXXX.tar flash:
%Error, "ftp://X.X.X.X/XXXX.tar" is a directory.
Conditions:
This problem is seen when executing the command:
archive tar /xtract
With the source file coming from an ftp or tftp server will result in an
error message indicating that the source file is a directory.
Workaround:
There is no known workaround.
Fix is in 12.4.13e, 12.4(11)XJ, 12.4.15T
478
