Community Member
Change point to point into point to multi point
I'm new to the UC500 and don't know how to set the voice from point to point into point to multi point, i'm using KPN euro ISDN multi point ? can some one help me out?
Hall of Fame Super Gold
Re: Change point to point into point to multi point
By default, the ISDN BRI is set for multipoint. In this case is recommended that you use "isdn tei-negotiation preserve" under BRI interface.
If you want point-to-point, use "isdn static-tei 0".
Community Member
Dear p.bevilacqua,
I do question that, i use a not multi isdn and than it's working when i do use the multi isdn it's not working.
Thanx andy
Which exact IOS are you using ?
Community Member
I don't know at the moment. I'm not at the location where the UC500 is placed. Didn't set SSH open for i-net at the moment so can't login remote.
Why is there a trouble with older ones?
You need to run 12.4(11)XW5, previous ones are buggy.
Community Member
Thanx for the info i'll try it tommorow
173
