Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Channel selection order under ISDN E1 PRI
We have the following VoIP setup:
Site1_PBX---VoIPgw--**network**--VoIPgw--Site2_PBX
ISDN type: E1 PRI
Both gateways have 03 E1 PRI setup, so total, we have 90 B channels. It seems the router select the B channel randomly.
We need to have a logical sequence of B selection for each gateway:
First E1 will be selected and B channel will be selected from 1 to 30 sequencially
the second E1 will be selected once the first e1 is fully used (all 30 B channels are used) and B channel will be selected from 1 to 30 sequencially
the third E1 will be selected once the first and the second e1 is fully used (all 30 B channels are used) and B channel will be selected from 1 to 30 sequencially
Thanks for your quick feedback as this is urgent for users
Mohamed
Hall of Fame Super Gold
Re: Channel selection order under ISDN E1 PRI
No the router does not select B-channel at random. It always uses ascending or descending order. To have an order whitin the different interfaces, configure them in a sequential trunk-group.
hello,
Thanks for your response.
Do you have any related documentation about trunk-group?
Which Cisco IOS command should i use?
Appreciate your help
Under serial x/y interface, specify a trunk-group with a name of your liking, and a priority if necessary.
Under DP pots, specify the same trunkgroup instead of port.
Optionally, under "trunk group ", you can configure additional options.
That's it.
As a recognition to those providing answers, please rate useful posts using the scrollbox below!
661
