Choppy calls with satellite connection
We have a DSL connecion of 2Mbits with a 1760 and on the other side is a satellite connection with direcway and 512 kbps and a 1751 the sound received in the direcway point is complete clear, but in the DSL side is choppy, the sound is very bad, i tried the direct connecion and the tunnel connection both without VPN, and the last is best, i cannot turn on rtp header compression because is a ethernet interface in the direcway side.
I use the codec g723ar53 no vad. some suggestion?
tnanks a lot
1 REPLY
Re: Choppy calls with satellite connection
Most likely you are hearing the effects of jitter.
Do you nhave any QOS configured:
http://cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a00800b2d29.shtml
201
