Choppy voice issue
adm.mercurio
I have here the following VoIP network structure:
Analog Phone 1<->PABX<->Gateway AS5350<->Router C6509<->Frame Relay Cloud<->Router 1751<->PABX<->Analog Phone 2
The two routers have both data and voice traffic. Supposing that Frame Relay bandwidth is 256 kbps, and the link is congested with data packets. When a phone call is made, we listen the voice with great quality on Phone 1, but on Phone 2 the quality is terrible (choppy voice).
I think something is wrong with the QoS on the 6509's outside packets. But I still wasn't able to find the problem in the config:
*********************** 6509 ***************************
interface Serial3/0/0.7 point-to-point
bandwidth 256
frame-relay interface-dlci 100
class VoIP256-256
map-class frame-relay VoIP256-256
no frame-relay adaptive-shaping
frame-relay cir 256000
frame-relay bc 2560
frame-relay be 0
frame-relay mincir 256000
service-policy output Shape2channels
frame-relay fragment 320
policy-map Shape2channels
shape average 256000 2048 0
service-policy VoIP2channels
policy-map VoIP2channels
class voice-signaling
bandwidth 8
class voice-traffic
priority 45
class class-default
fair-queue
class-map match-all voice-signaling
match access-group 103
class-map match-all voice-traffic
match access-group 102
access-list 102 permit udp any any range 16384 32767
access-list 103 permit tcp any eq 1720 any
access-list 103 permit tcp any any eq 1720
It seems the 6509 isn't giving priority to the voice packets. Or maybe can be a problem with traffic-shaping?
I've already made several changes in the config, specially in Shape2channels/VoIP2channels policies.
And when I execute the "show policy-map interface s3/0/0.7" command, it returns nothing to me (in fact, it returns a blank line...).
Someone have any idea of what is happening?
8 Replies 8
Hieu Cao
Level 4
Level 4
What is the QoS config of the 1750?
For the 6509, I suggest that you use the very basic QoS to start out to troubleshoot the problem, instead of using nested policy. Are you also running Video Conferencing over IP (1720)?
class-map match-all VoIP
match ip dscp ef
match ip dscp cs5
class-map match-all Video
match ip dscp af41 (if your video equipment is set for ip precedence 4, then use "match ip precedence 4 instead of dscp af41)
class-map match-any VoIP-Signaling
match ip dscp af31
match ip dscp cs3
class-map match-any Network-Control
match ip dscp cs6
policy-map VoIP-256
class VoIP
priority percent 45
class Video
priority percent xx
class VoIP-Signaling
bandwidth percent 3
class Network-Control
bandwidth percent 3
class class-default
fair-queue
random-detect dscp-based
Apply "service-policy output VoIP-256" to your interface.
Use the same QoS in the 1751 and check the QoS output for any drop packet in VoIP class.
HTH,
hieu
Hieu, thanks for the help!
No, i'm not running video conference right now.
The config of the 1751 is more simple:
interface Serial0/0
bandwidth 256
frame-relay traffic-shaping
frame-relay interface-dlci 101
class VoIP256-256
frame-relay bc 2560
frame-relay be 0
service-policy output VoIP2canais
frame-relay fragment 160
policy-map VoIP2canais
bandwidth 8
class voice-traffic
priority 45
class class-default
fair-queue
I've made the changes for this PVC in the 6509, and I think it work on the first time.
But I've made the same test in another PVC that has the same issue and it doesn't work. The strange thing is that when I use the "show policy-map interface" on the interface of this PVC, it returns just a blank line on the screen, and before the changes the command was working alright. So I've returned for the original config, but the command insists in show just the blank line, it doesn't work anymore...
Take a look at this document regarding setting up QoS for FR.
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_configuration_example09186a0080094af9.shtml
When things don't seem to work right, I would recommend that you use basic config first, verifying that it's working before adding anything else like nested policy or cRTP (compressed RTP).
HTH,
hieu
Well, I tried to implement the basic IP RTP Priority, but it didn't work. But since I never used this QoS method, I don't know if the config is right:
bandwidth 256
class VoIP256-256
frame-relay bc 2560
frame-relay be 0
frame-relay ip rtp priority 16384 16383 45
frame-relay fair-queue
This is the same as the example on Cisco's document.
Then I made a big data transfer and a phone call at the same time, but the voice is still breaking, a lot.
I have here a star topology, and all the edges have the same problem.
In one PVC the LLQ method based on dscp have worked well. But after I changed the policies on the other PVCs, when I use the "show policy-map interface" it shows nothing. It seems that the policy doesn't attach to the interface. The only PVC that this command works is the PVC that LLQ QoS is working.
Do you know why this is happening?
Your config looks right per the Cisco doc., butI am not exactly sure what's happening in your enviroment. Since you know that LLQ works fine, then you might want to try it again.
Sample config:
OK..since you know that LLQ works fine, then try to implement LLQ again
class-map VoIP256
match ip dscp ef
class-map Call-Signaling
match ip dscp af31
match ip dscp cs3
policy-map VoIP
class VoIP256
priority percent 50
class Call-Signaling
bandwidth percent 3
class class-default
fair-queue
Notice that the "priority percent" command, not just "priority" as shown in your previous config. Since "priority 45" only allocates "45 Kbps" for voice, I don't think it's sufficent bw for VoIP. With "priority percent 50", you're allocating 128 Kbps for VoIP.
Let me know if this works out any better..
HTH,
hieu
The show policy-map interface command dosen't work when using frame relay priority queuing in the map class. It only works with policy maps.
Please rate helpful posts.
Dave
dford333
I notices that there isnt any prioritztion since your packets arent map with DSCP. your policy map and frame relay traffic shaping seems ok but where are you marking your packets
class-map match-all L3-to-L2_VoIP-Cntrl
match ip dscp af31
class-map match-all L3-to-L2_VoIP-RTP
match ip dscp ef
class-map match-all SIP
match protocol sip
class-map match-all ef-bit
--More-- match cos 5
match ip dscp ef
class-map match-all RTP
match protocol rtp
policy-map EthOut
class RTP
policy-map output-L3-to-L2
class L3-to-L2_VoIP-RTP
set cos 5
class L3-to-L2_VoIP-Cntrl
set cos 3
policy-map voice
class ef-bit
priority percent 15
you have to mark your packets so your can prioritzed you voice packet with LLQ or CBWFQ
Well, after a month of research I finally discovered the problem:
The 6509 does not do QoS on FlexWAN subinterfaces...
That's why QoS does'nt work. In fact it never worked.
So I think that we will have to put another router in front of 6509 to do this QoS. For now, is the only solution that I see on the horizon. And since we are changing the network topology, this is already in our plan.
But I want to thank everyone for your help. Now that I found this forum, certainly I'll come back here if I have another problem.
Regards.
