Cisco 1760 SIP-to-SIP GW T.38 does not work!
Hello!
Diagram is something like this:  Softswitch(MERA) -->>-- Cisco1760 -->>-- Softswitch(MERA)   It's needed to limit traffic if one of SSWs is hacked. But it is not a subject. We just need such "construction".
1. Voice calls are sent and received fine in diagram above.
2. Fax are passed good between two Softswitches if I exclude Cisco1760.
3. Faxes are stopped immediately when I re-route voice traffic through Cisco1760 (in the same conditions on both Softswitches as in above paragraph 2. That is, Faxes are passed between Softswitches directly, I don't change anything on Softswitches, and I just re-route Voice from both Softswitches on C1760 - Faxes stop immediately).
4. Relevant configuraion:
voice service voip
allow-connections sip to sip
voice class uri  Centrex sip
host ^10\.0\.99\.111$
voice class codec 1
codec preference 1 g711alaw
codec preference 2 clear-channel
voice translation-rule 112
rule 1 /^000112\(.*\)$/ /\1/
voice translation-rule 999
rule 1 /^999\(.*\)$/ /000\1/
voice translation-rule 999112
rule 1 /^\(.*\)$/ /999112\1/
voice translation-profile 112
translate called 112
voice translation-profile 999
translate called 999
voice translation-profile 999112
translate called 999112
interface FastEthernet0/0.18
encapsulation dot1Q 18
ip address 10.0.99.29 255.255.255.0
dial-peer voice 999112 voip
translation-profile incoming 999112
session protocol sipv2
incoming uri from Centrex
dtmf-relay rtp-nte
codec g711alaw
fax-relay ecm disable
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
no vad
dial-peer voice 999 voip
translation-profile outgoing 999
destination-pattern 999.+
session target ipv4:10.0.99.99
session transport udp
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 112 voip
translation-profile outgoing 112
destination-pattern 000112.+
session target ipv4:10.0.99.100
dtmf-relay rtp-nte
codec g711alaw
no vad
5. TSHARK from left-side Softswitch:
17:13:13.378768   10.0.99.31 -> 10.0.99.99   SIP/SDP Request: INVITE sip:0000034957887603@10.0.99.99, with session description
17:13:13.379991   10.0.99.99 -> 10.0.99.31   SIP Status: 100 Trying
17:13:13.407132  10.0.99.121 -> 10.0.99.29   SIP/SDP Request: INVITE sip:0001124957887603@10.0.99.29;user=phone, with session description
17:13:13.451394   10.0.99.29 -> 10.0.99.121  SIP Status: 100 Trying
17:13:17.136950   10.0.99.29 -> 10.0.99.121  SIP/SDP Status: 183 Session Progress, with session description
17:13:17.138247   10.0.99.99 -> 10.0.99.31   SIP/SDP Status: 183 Progress, with session description
17:13:17.164218   10.0.99.29 -> 10.0.99.121  SIP Status: 180 Ringing
17:13:17.164996   10.0.99.99 -> 10.0.99.31   SIP Status: 180 Ringing
17:13:20.759614   10.0.99.29 -> 10.0.99.121  SIP/SDP Status: 200 OK, with session description
17:13:20.760605  10.0.99.121 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
17:13:20.760900   10.0.99.99 -> 10.0.99.31   SIP/SDP Status: 200 OK, with session description
17:13:20.764072   10.0.99.31 -> 10.0.99.99   SIP Request: ACK sip:0000034957887603@10.0.99.99:5060
17:13:25.966560   10.0.99.29 -> 10.0.99.121  SIP Status: 488 Not Acceptable Media
17:13:25.966742  10.0.99.121 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
17:13:26.461352   10.0.99.29 -> 10.0.99.121  SIP/SDP Status: 200 OK, with session description
17:13:26.461590  10.0.99.121 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
17:13:27.463414   10.0.99.29 -> 10.0.99.121  SIP/SDP Status: 200 OK, with session description
17:13:27.463607  10.0.99.121 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
17:13:29.466615   10.0.99.29 -> 10.0.99.121  SIP/SDP Status: 200 OK, with session description
17:13:29.466857  10.0.99.121 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
17:13:33.468848   10.0.99.29 -> 10.0.99.121  SIP/SDP Status: 200 OK, with session description
17:13:33.469094  10.0.99.121 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
17:13:37.471399   10.0.99.29 -> 10.0.99.121  SIP/SDP Status: 200 OK, with session description
17:13:37.471640  10.0.99.121 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
17:13:41.473934   10.0.99.29 -> 10.0.99.121  SIP/SDP Status: 200 OK, with session description
17:13:41.474186  10.0.99.121 -> 10.0.99.29   SIP Request: ACK sip:0001124957887603@10.0.99.29:5060
17:13:45.476350   10.0.99.29 -> 10.0.99.121  SIP Request: BYE sip:4991589848@10.0.99.121:5061;user=phone
17:13:45.477024  10.0.99.121 -> 10.0.99.29   SIP Status: 200 OK
17:13:45.478244   10.0.99.99 -> 10.0.99.31   SIP Request: BYE sip:4991589848@10.0.99.31
17:13:45.481451   10.0.99.31 -> 10.0.99.99   SIP Status: 200 OK
6. TSHARK from right-side Softswitch:
17:13:13.451863   10.0.99.29 -> 10.0.99.100  SIP/SDP Request: INVITE sip:4957887603@10.0.99.100:5060, with session description
17:13:13.453671  10.0.99.100 -> 10.0.99.29   SIP Status: 100 Trying
17:13:17.112355  10.0.99.100 -> 10.0.99.29   SIP/SDP Status: 183 Progress, with session description
17:13:17.152182  10.0.99.100 -> 10.0.99.29   SIP Status: 180 Ringing
17:13:20.732050  10.0.99.100 -> 10.0.99.29   SIP/SDP Status: 200 OK, with session description
17:13:20.757095   10.0.99.29 -> 10.0.99.100  SIP Request: ACK sip:4957887603@10.0.99.100:5060
17:13:25.937863  10.0.99.100 -> 10.0.99.29   SIP/SDP Request: INVITE sip:4991589848@10.0.99.29:5060, with session description
17:13:25.964372   10.0.99.29 -> 10.0.99.100  SIP Status: 100 Trying
17:13:25.967495   10.0.99.29 -> 10.0.99.100  SIP/SDP Status: 200 OK, with session description
17:13:25.968264  10.0.99.100 -> 10.0.99.29   SIP Request: ACK sip:4991589848@10.0.99.29:5060
17:13:45.483358   10.0.99.29 -> 10.0.99.100  SIP Request: BYE sip:4957887603@10.0.99.100:5060
17:13:45.484600  10.0.99.100 -> 10.0.99.29   SIP Status: 200 OK
7. DEBUG of "debug ccsip messages", "debug voip vtsp all", "debug fax relay t30 all-level-1" doesn't tell me something interesting except "SIP/2.0 488 Not Acceptable Media" and "Warning: 304 10.0.99.29 "Media Type(s) Unavailable". But I can't explain what is wrong basing on these messages.
*Mar  1 09:30:25.856: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0001124957873222@10.0.99.29;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.0.99.221:5061;rport;branch=z9hG4bK-1386031750-3776042726-436258467-408012644
From: <sip:4956662825@10.0.99.221:5061;user=phone>;tag=4268632710-3776042726-436258467-408012644
To: <sip:0001124957873222@10.0.99.29;user=phone>
Call-ID: 862a6f26e6d611e1a3c6001a64c75118@10.0.99.221
CSeq: 1 INVITE
Contact: <sip:4956662825@10.0.99.221:5061;user=phone>
Content-Type: application/sdp
Allow: ACK, BYE, CANCEL, INFO, INVITE, OPTIONS, REFER, REGISTER, UPDATE
Max-Forwards: 70
User-Agent: MERA MVTS3G v.4.4.0-15
Cisco-Guid: 2250716610-3872788961-2747662362-1690784024
Content-Length:   313
v=0
o=- 1345034484 1345034484 IN IP4 10.0.99.121
s=-
c=IN IP4 10.0.99.121
t=0 0
m=audio 14596 RTP/AVP 8 0 18 4 96
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:4 G723/8000
a=fmtp:4 annexa=yes
a=rtpmap:96 telephone-event/8000
a=fmtp:96 0-15
a=sendrecv
*Mar  1 09:30:25.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <sip:0001124957873222@10.0.99.29;user=phone>;tag=19D67FA-141A
Date: Fri, 01 Mar 2002 09:30:25 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 INVITE
Allow-Events: telephone-event
Content-Length: 0
*Mar  1 09:30:25.900: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4957873222@10.0.99.100:5060 SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bK1C312FF
To: <sip:4957873222@10.0.99.100>
Call-ID: CBD44AE3-2C2D11D6-8170B4BF-FDD95F40@10.0.99.29
Supported: 100rel,timer,replaces
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Remote-Party-ID: <sip:4956662825@10.0.99.29>;party=calling;screen=no;privacy=off
Timestamp: 1014975025
Contact: <sip:4956662825@10.0.99.29:5060>
Expires: 180
Content-Length: 241
v=0
o=CiscoSystemsSIP-GW-UserAgent 7293 6321 IN IP4 10.0.99.29
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
m=audio 17584 RTP/AVP 8 101
c=IN IP4 10.0.99.29
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
*Mar  1 09:30:25.908: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Contact: <sip:4957873222@10.0.99.100:5060>
Server: MERA MVTS3G v.4.4.0-15
Content-Length: 0
*Mar  1 09:30:25.992: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:4957873222@10.0.99.100>;tag=4168730000-3776042726-436221351-2287060836
CSeq: 101 INVITE
Content-Length:   239
v=0
o=- 1345034484 1345034484 IN IP4 10.0.99.111
s=-
c=IN IP4 10.0.99.111
t=0 0
m=audio 41872 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
a=silenceSupp:off - - - -
*Mar  1 09:30:26.016: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow: ACK, BYE, CANCEL, INFO, INVITE, OPTIONS, REFER, REGISTER, SUBSCRIBE, UPDATE
X-mera-expires: 86460
Content-Length:   239
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
*Mar  1 09:30:26.028: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
CSeq: 1 INVITE
Contact: <sip:0001124957873222@10.0.99.29:5060>
Content-Disposition: session;handling=required
Content-Length: 255
v=0
o=CiscoSystemsSIP-GW-UserAgent 6770 138 IN IP4 10.0.99.29
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
m=audio 16536 RTP/AVP 8 101
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  1 09:30:26.032: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4957873222@10.0.99.100:5060 SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bK1C42444
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Mar  1 09:30:26.048: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Content-Length: 255
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  1 09:30:26.052: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0001124957873222@10.0.99.29:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.99.221:5061;rport;branch=z9hG4bK-1651787910-3776042726-436258467-408012644
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  1 09:30:37.143: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0001124957887603@10.0.99.29;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.0.99.221:5061;rport;branch=z9hG4bK-3398558860-3776042726-436258467-408012644
From: <sip:4991589848@10.0.99.221:5061;user=phone>;tag=2590499980-3776042726-436258467-408012644
To: <sip:0001124957887603@10.0.99.29;user=phone>
Call-ID: 8ce467cce6d611e1a3c6001a64c75118@10.0.99.221
CSeq: 1 INVITE
Contact: <sip:4991589848@10.0.99.221:5061;user=phone>
Max-Forwards: 70
Cisco-Guid: 2363541220-3872788961-2747662362-1690784024
Category: 10
Content-Length:   313
v=0
o=- 1345034495 1345034495 IN IP4 10.0.99.121
s=-
t=0 0
m=audio 14612 RTP/AVP 8 0 18 4 96
a=fmtp:18 annexb=no
a=fmtp:4 annexa=yes
a=fmtp:96 0-15
a=sendrecv
*Mar  1 09:30:37.187: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <sip:0001124957887603@10.0.99.29;user=phone>;tag=19D9411-24AB
Date: Fri, 01 Mar 2002 09:30:37 GMT
CSeq: 1 INVITE
Content-Length: 0
Sent:
INVITE sip:4957887603@10.0.99.100:5060 SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bK1C587B
To: <sip:4957887603@10.0.99.100>
Call-ID: D28F17F3-2C2D11D6-8172B4BF-FDD95F40@10.0.99.29
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Remote-Party-ID: <sip:4991589848@10.0.99.29>;party=calling;screen=no;privacy=off
Timestamp: 1014975037
Contact: <sip:4991589848@10.0.99.29:5060>
Expires: 180
Content-Length: 240
v=0
o=CiscoSystemsSIP-GW-UserAgent 8957 620 IN IP4 10.0.99.29
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
m=audio 17280 RTP/AVP 8 101
c=IN IP4 10.0.99.29
a=fmtp:101 0-16
a=ptime:20
*Mar  1 09:30:37.195: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Contact: <sip:4957887603@10.0.99.100:5060>
Content-Length: 0
Router#
*Mar  1 09:30:40.829: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Progress
To: <sip:4957887603@10.0.99.100>;tag=3740303255-3776042726-436221351-2287060836
CSeq: 101 INVITE
Content-Length:   239
v=0
o=- 1345034499 1345034499 IN IP4 10.0.99.111
s=-
t=0 0
m=audio 17418 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
*Mar  1 09:30:40.853: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Contact: <sip:0001124957887603@10.0.99.29:5060>
Content-Length: 255
v=0
o=CiscoSystemsSIP-GW-UserAgent 3388 542 IN IP4 10.0.99.29
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
m=audio 18290 RTP/AVP 8 101
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  1 09:30:40.885: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
*Mar  1 09:30:40.893: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Router#O, UPDATE, REGISTER
Content-Length: 0
Router#
*Mar  1 09:30:44.487: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length:   239
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
*Mar  1 09:30:44.511: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4957887603@10.0.99.100:5060 SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bK1C6104C
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Mar  1 09:30:44.515: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Content-Length: 255
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  1 09:30:44.519: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0001124957887603@10.0.99.29:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.99.221:5061;rport;branch=z9hG4bK-3359459985-3776042726-436258467-408012644
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  1 09:30:49.679: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:4991589848@10.0.99.29:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.99.100:5060;rport;branch=z9hG4bK-2318135710-3776042726-436221351-22870608361
Via: SIP/2.0/UDP 10.0.99.100:5061;rport=5061;branch=z9hG4bK-2318135710-3776042726-436221351-2287060836;received=10.0.99.100
From: <sip:4957887603@10.0.99.100>;tag=3740303255-3776042726-436221351-2287060836
To: <sip:4991589848@10.0.99.29>;tag=19D9431-3FB
CSeq: 102 INVITE
Max-Forwards: 70
Content-Length:   193
v=0
o=- 1345034508 1345034508 IN IP4 10.0.99.111
s=-
t=0 0
m=image 17418 udptl t38
a=T38FaxRateManagement:transferredTCF
a=T38FaxUdpEC:t38UDPRedundancy
a=sendrecv
*Mar  1 09:30:49.703: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.0.99.100:5060;rport;branch=z9hG4bK-2318135710-3776042726-436221351-22870608361,SIP/2.0/UDP 10.0.99.100:5061;rport=5061;branch=z9hG4bK-2318135710-3776042726-436221351-2287060836;received=10.0.99.100
Date: Fri, 01 Mar 2002 09:30:49 GMT
CSeq: 102 INVITE
Remote-Party-ID: <sip:4991589848@10.0.99.29>;party=called;screen=no;privacy=off
Content-Length: 0
*Mar  1 09:30:49.707: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
*Mar  1 09:30:49.711: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Content-Length: 150
v=0
o=CiscoSystemsSIP-GW-UserAgent 8957 621 IN IP4 10.0.99.29
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
m=image 17280 udptl t38
c=IN IP4 10.0.99.29
*Mar  1 09:30:49.719: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  1 09:30:49.727: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:4991589848@10.0.99.29:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.99.100:5060;rport;branch=z9hG4bK-582743710-3776042726-436221351-22870608361
Via: SIP/2.0/UDP 10.0.99.100:5061;rport=5061;branch=z9hG4bK-582743710-3776042726-436221351-2287060836;received=10.0.99.100
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  1 09:30:50.204: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Content-Length: 255
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  1 09:30:50.208: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  1 09:30:51.206: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 01 Mar 2002 09:30:50 GMT
CSeq: 1 INVITE
Supported: replaces
Content-Length: 255
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  1 09:30:51.214: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  1 09:30:53.209: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 01 Mar 2002 09:30:51 GMT
CSeq: 1 INVITE
Supported: replaces
Content-Length: 255
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  1 09:30:53.217: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  1 09:30:57.212: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 01 Mar 2002 09:30:53 GMT
CSeq: 1 INVITE
Supported: replaces
Content-Length: 255
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  1 09:30:57.220: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  1 09:31:01.214: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 01 Mar 2002 09:30:57 GMT
CSeq: 1 INVITE
Supported: replaces
Content-Length: 255
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  1 09:31:01.222: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  1 09:31:05.217: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 01 Mar 2002 09:31:01 GMT
CSeq: 1 INVITE
Supported: replaces
Content-Length: 255
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  1 09:31:05.225: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  1 09:31:09.219: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:4991589848@10.0.99.221:5061;user=phone SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bK1C7D0
From: <sip:0001124957887603@10.0.99.29;user=phone>;tag=19D9411-24AB
To: <sip:4991589848@10.0.99.221:5061;user=phone>;tag=2590499980-3776042726-436258467-408012644
Date: Fri, 01 Mar 2002 09:31:05 GMT
Max-Forwards: 70
Timestamp: 1014975069
CSeq: 101 BYE
Content-Length: 0
*Mar  1 09:31:09.223: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Content-Length: 0
*Mar  1 09:31:09.239: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:4957887603@10.0.99.100:5060 SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bK1C82274
Max-Forwards: 70
CSeq: 102 BYE
Content-Length: 0
*Mar  1 09:31:09.243: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
8. Output of "show version" command executed on C1760:
Cisco IOS Software, C1700 Software (C1700-ADVENTERPRISEK9-M), Version 12.4(25c), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 11-Feb-10 22:24 by prod_rel_team
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
Router uptime is 9 hours, 14 minutes
System image file is "flash:c1700-adventerprisek9-mz.124-25c.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1760 (MPC860P) processor (revision 0x851) with 92494K/5810K bytes of memory.
Processor board ID FOC0951580U (2749394119), with hardware revision 0000
MPC860P processor: part number 5, mask 2
1 FastEthernet interface
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
May you help me?
Kind regards,
Ellad Yatsko
Is anybody here? :-)
Kind regards,
Ellad
You can check what incoming dial-peer is used.
Use the command "show voice call status" during a call:
C1760-GATEWAY2#sh voice call status
CallID     CID  ccVdb      Port        DSP/Ch  Called #   Codec    Dial-peers
0x5D85D    1DF  0x83A638AC 0/0                *****        g711alaw 3/100
1 active call found
In the example above, the incoming dp is the number 3 and outgoing dp is the 100.
If no incoming dial-peers are matched, the cisco uses the hidden dial-peer zero. In this case T.38 is disable.
Regards.
What's wrong with me?.. :-)
I've issued command twice:
Router#show voice call status
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    Dial-peers
No active calls found
Router#
First time when voice call extablished, and second time when Fax began.
I made two additional dial-peers - for both servers in cluster of left-side Softswitch (10.0.99.121 and 10.0.99.221), and now my Dial-peers looks like that:
dtmf-relay rtp-nte
codec transparent
fax protocol t38 ls-redundancy 3 hs-redundancy 0 fallback none
no vad
dtmf-relay rtp-nte
codec transparent
no vad
dtmf-relay rtp-nte
codec transparent
no vad
dial-peer voice 901 voip
incoming uri from RTU1
dtmf-relay rtp-nte
codec transparent
no vad
dial-peer voice 902 voip
incoming uri from RTU2
dtmf-relay rtp-nte
codec transparent
no vad
So, now I have dial-peers for all cases of life! :-) And I see that 901/902 dial-peers are selected during the same schema call:
Router#debug voice dialpeer
voip dialpeer default debugging is on
Router#terminal monitor
Router#
*Mar  3 01:34:47.183: //-1/EAABC390ACBA/DPM/dpAssociateIncomingPeerCore:
   Calling Number=4991589848, Called Number=0001124957887603, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
*Mar  3 01:34:47.187: //-1/EAABC390ACBA/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_FROM_URI; Incoming Dial-peer=901
*Mar  3 01:34:47.207: //-1/EAABC390ACBA/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=0001124957887603, Peer Info Type=DIALPEER_INFO_SPEECH
*Mar  3 01:34:47.211: //-1/EAABC390ACBA/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=0001124957887603
   Result=Success(0) after DP_MATCH_DEST
*Mar  3 01:34:47.211: //-1/EAABC390ACBA/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=112
Router#
*Mar  3 01:34:51.034: %SIP-3-UNSUPPORTED: Unsupported ptime value
Router#
*Mar  3 01:34:54.716: %SIP-3-UNSUPPORTED: Unsupported ptime value
Router#
But...:
And what could it be:
Packetization time is set to 20 ms everywhere..
Kind regards,
Ellad
I eliminated "%SIP-3-UNSUPPORTED: Unsupported ptime value" messages - I indicated explicitly "voice-class codec 1", and in "voice class codec 1" in "codec preference preference 1 g711alaw bytes 80" added "bytes 80" which means I guess 20 ms ptime.
But the problem with "488 Not Acceptable Media" does still remain..
What is the IOS version used?
Do you already try to add a "fax rate" in dial-peer config?
Can you add the output of "debug voice ccapi inout?
Regards.
As for version:
Cisco IOS Software, C1700 Software (C1700-IPVOICEK9-M), Version 12.4(25d), RELEASE SOFTWARE (fc1)
Compiled Wed 18-Aug-10 03:47 by prod_rel_team
Router uptime is 1 day, 4 hours, 22 minutes
System returned to ROM by reload
System image file is "flash:c1700-ipvoicek9-mz.124-25d.bin"
Cisco 1760 (MPC860P) processor (revision 0x851) with 89590K/8714K bytes of memory.
32K bytes of NVRAM.
All dial-peers had "rate" command included. But at some moment I deleted it. Now it is included again.
Router#debug voice ccapi inout
voip ccapi inout debugging is on
*Mar  3 06:20:10.990: //-1/CBE5AF5CA3C6/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_FROM_URI; Incoming Dial-peer=902
*Mar  3 06:20:10.994: //1177/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Call Entry Is Not Found
*Mar  3 06:20:10.998: //-1/CBE5AF5CA3C6/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=4991589848
   ----- ccCallInfo IE subfields -----
   cisco-ani=4991589848
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=0001124957887603
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=-1
*Mar  3 06:20:10.998: //-1/CBE5AF5CA3C6/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x83797348, Call Info(
   Calling Number=4991589848(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=0001124957887603(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=902, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1177
*Mar  3 06:20:10.998: //-1/CBE5AF5CA3C6/CCAPI/ccCheckClipClir:
   In: Calling Number=4991589848(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Mar  3 06:20:11.002: //-1/CBE5AF5CA3C6/CCAPI/ccCheckClipClir:
   Out: Calling Number=4991589848(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Mar  3 06:20:11.002: //1177/CBE5AF5CA3C6/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=4991589848(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=0001124957887603(TON=Unknown, NPI=Unknown))
*Mar  3 06:20:11.006: //1177/CBE5AF5CA3C6/CCAPI/cc_process_call_setup_ind:
   Event=0x8395A978
*Mar  3 06:20:11.006: //1177/CBE5AF5CA3C6/CCAPI/ccCallSetContext:
   Context=0x83C702B0
*Mar  3 06:20:11.010: //1177/CBE5AF5CA3C6/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 1177 with tag 902 to app "_ManagedAppProcess_Default"
*Mar  3 06:20:11.010: //1177/CBE5AF5CA3C6/CCAPI/ccCallProceeding:
*Mar  3 06:20:11.014: //-1/CBE5AF5CA3C6/DPM/dpMatchPeersCore:
*Mar  3 06:20:11.014: //-1/CBE5AF5CA3C6/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Mar  3 06:20:11.018: //1177/CBE5AF5CA3C6/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=112, Params=0x83C78B20, Progress Indication=NULL(0)
*Mar  3 06:20:11.018: //1177/CBE5AF5CA3C6/CCAPI/ccCheckClipClir:
*Mar  3 06:20:11.022: //1177/CBE5AF5CA3C6/CCAPI/ccCallSetupRequest:
   Destination Pattern=000112.+, Called Number=4957887603, Digit Strip=FALSE
   Called Number=4957887603(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=4991589848, Final Destination Flag=TRUE,
   Guid=CBE5AF5C-E84E-11E1-A3C6-001A64C75118, Outgoing Dial-peer=112
*Mar  3 06:20:11.022: //1177/CBE5AF5CA3C6/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4957887603
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Mar  3 06:20:11.026: //1177/CBE5AF5CA3C6/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x83797348, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=4991589848(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=4957887603(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=112, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Mar  3 06:20:11.026: //1178/CBE5AF5CA3C6/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*Mar  3 06:20:11.026: //1178/CBE5AF5CA3C6/CCAPI/ccCallSetContext:
   Context=0x83C78AD0
*Mar  3 06:20:11.026: //1177/CBE5AF5CA3C6/CCAPI/ccSaveDialpeerTag:
*Mar  3 06:20:11.030: //1178/CBE5AF5CA3C6/CCAPI/cc_api_call_proceeding:
   Interface=0x83797348, Progress Indication=NULL(0)
*Mar  3 06:20:14.700: //1178/CBE5AF5CA3C6/CCAPI/cc_api_event_indication:
   Event=132, Call Id=1178
   Event Is Sent To Conferenced SPI(s) Directly
*Mar  3 06:20:14.704: //1178/CBE5AF5CA3C6/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=1178,
   Caps(Codec=0x0, Fax Rate=0x83C24930, Vad=0x80AB62D8,
   Modem=0x80CD3430, Codec Bytes=0, Signal Type=0)
   Caps(Playout Mode=0, Playout Initial=0(ms), Playout Min=0(ms),
   Playout Max=0(ms), Fax Nom=33730(ms))
*Mar  3 06:20:14.704: //1177/CBE5AF5CA3C6/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=1177,
   Caps(Codec=g711alaw(0x2), Fax Rate=FAX_RATE_9600(0x20), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=80, Signal Type=2, Seq Num Start=1)
*Mar  3 06:20:14.704: //1178/CBE5AF5CA3C6/CCAPI/cc_api_call_cut_progress:
   Interface=0x83797348, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=0
   Call Entry(Responsed=TRUE)
*Mar  3 06:20:14.708: //1177/CBE5AF5CA3C6/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(AlertSent=FALSE)
*Mar  3 06:20:14.712: //1177/CBE5AF5CA3C6/CCAPI/ccCallCutProgress:
*Mar  3 06:20:14.712: //1177/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x82BB8770, callID1=0x499, callID2=0x49A, tag=0x0)
*Mar  3 06:20:14.712: //1177/CBE5AF5CA3C6/CCAPI/ccConferenceCreate:
   Conference Id=0x82BB8770, Call Id1=1177, Call Id2=1178, Tag=0x0
*Mar  3 06:20:14.712: ccConferenceCreate: ret1=0, codecMask1=2, bytes1=80, negot1=1
                    ret2=0, codecMask2=2, bytes2=80, negot2=1
*Mar  3 06:20:14.712: //1177/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Mar  3 06:20:14.712: cc_api_get_xcode_stream : 4181
*Mar  3 06:20:14.716: //1177/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x211, Source Interface=0x83797348, Source Call Id=1177,
   Destination Call Id=1178, Disposition=0x0, Tag=0x0
*Mar  3 06:20:14.716: //1178/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Mar  3 06:20:14.716: cc_api_get_xcode_stream : 4181
*Mar  3 06:20:14.716: //1178/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x211, Source Interface=0x83797348, Source Call Id=1178,
   Destination Call Id=1177, Disposition=0x0, Tag=0x0
*Mar  3 06:20:14.716: //1177/CBE5AF5CA3C6/CCAPI/cc_generic_bridge_done:
*Mar  3 06:20:14.720: //1177/CBE5AF5CA3C6/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x211, Destination Call Id=1178)
*Mar  3 06:20:14.720: //1178/CBE5AF5CA3C6/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x211, Destination Call Id=1177)
*Mar  3 06:20:14.720: //1177/CBE5AF5CA3C6/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x211, Call Id1=1177, Call Id2=1178
*Mar  3 06:20:14.732: //1178/CBE5AF5CA3C6/CCAPI/cc_api_call_alert:
   Interface=0x83797348, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
*Mar  3 06:20:14.740: //1177/CBE5AF5CA3C6/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, AlertSent=TRUE)
Router#
*Mar  3 06:20:18.362: //1178/CBE5AF5CA3C6/CCAPI/cc_api_call_connected:
   Interface=0x83797348, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*Mar  3 06:20:18.366: //1177/CBE5AF5CA3C6/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x0
*Mar  3 06:20:18.370: //1177/CBE5AF5CA3C6/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
*Mar  3 06:20:23.559: //1177/CBE5AF5CA3C6/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=1177
*Mar  3 06:20:23.563: //1177/CBE5AF5CA3C6/CCAPI/cc_api_remote_codec_dnld_done:
   Destination Interface=0x83797348, Destination Call Id=1177, Source Call Id=1178, Xmit Function=0x81AB0204
*Mar  3 06:20:23.563: //1178/CBE5AF5CA3C6/CCAPI/cc_api_modify_media_ind:
   IFType=0x3, Source Call Id=0x49A, Destination Call Id=0x499,
   Codec=65536, Codec Bytes=-2085944036
*Mar  3 06:20:43.087: //1177/CBE5AF5CA3C6/CCAPI/cc_api_call_disconnected:
   Cause Value=127, Interface=0x83797348, Call Id=1177
   Call Entry(Responsed=TRUE, Cause Value=127, Retry Count=0)
*Mar  3 06:20:43.091: //1177/CBE5AF5CA3C6/CCAPI/ccConferenceDestroy:
   Conference Id=0x211, Tag=0x0
*Mar  3 06:20:43.091: //1177/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*Mar  3 06:20:43.091: //1178/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*Mar  3 06:20:43.091: //1177/CBE5AF5CA3C6/CCAPI/cc_generic_bridge_done:
*Mar  3 06:20:43.099: //1177/CBE5AF5CA3C6/CCAPI/ccCallDisconnect:
   Cause Value=127, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=127)
   Cause Value=127, Call Entry(Responsed=TRUE, Cause Value=127)
*Mar  3 06:20:43.099: //1178/CBE5AF5CA3C6/CCAPI/ccCallDisconnect:
   Cause Value=127, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*Mar  3 06:20:43.111: //1177/CBE5AF5CA3C6/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x83797348, Tag=0x0, Call Id=1177,
   Call Entry(Disconnect Cause=127, Voice Class Cause Code=0, Retry Count=0)
*Mar  3 06:20:43.115: //1177/CBE5AF5CA3C6/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
*Mar  3 06:20:43.127: //1178/CBE5AF5CA3C6/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x83797348, Tag=0x0, Call Id=1178,
Kind regards,
Ellad
voice-class codec 1
dtmf-relay rtp-nte
fax rate 9600
fax nsf 000000
fax protocol t38 ls-redundancy 3 hs-redundancy 0 fallback pass-through g711alaw
no vad
voice-class codec 1
dtmf-relay rtp-nte
fax rate 9600
fax nsf 000000
no vad
voice-class codec 1
dtmf-relay rtp-nte
fax rate 9600
fax nsf 000000
no vad
voice-class codec 1
dtmf-relay rtp-nte
fax rate 9600
fax nsf 000000
no vad
voice-class codec 1
dtmf-relay rtp-nte
fax rate 9600
fax nsf 000000
no vad
13:38:40.505101   10.0.99.29 -> 10.0.99.221  SIP Status: 488 Not Acceptable Media
The debug is truncated. Can you attach a full "debug ccsip message" and "debug voice ccapi inout"?
Do you already try a different IOS, e.g. c1700-ipvoice-mz.124-15.T14.bin?
Thanks.
Hello, Daniele!
Log is below. I tried "ipvoice" and "adventerprise" and both are with the same effect. When getting the log I wait for a minute (or approxiamately that) after a call is finished. When messages stopped I copied/pasted log here.
Kind regards,
Ellad
*Mar  6 12:30:34.049: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.0.99.121:5061;rport;branch=z9hG4bK-2533193478-3776044778-436261804-3629041508
From: <4991589848>;tag=2395895558-3776044778-436261804-3629041508
To: <0001124957887603>
Call-ID: 0677ceb6eade11e1acd3001a64c74ed8@10.0.99.121
CSeq: 1 INVITE
Contact: <4991589848>
Max-Forwards: 70
Cisco-Guid: 108265778-3940422113-2899509274-1690783448
Category: 10
Content-Length:   313
v=0
o=- 1345477515 1345477515 IN IP4 10.0.99.221
s=-
c=IN IP4 10.0.99.221
t=0 0
m=audio 23366 RTP/AVP 8 0 18 4 96
a=fmtp:18 annexb=no
a=fmtp:4 annexa=yes
a=fmtp:96 0-15
a=sendrecv
*Mar  6 12:30:34.061: //2185/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
*Mar  6 12:30:34.065: //-1/06740132ACD3/CCAPI/cc_api_display_ie_subfields:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Mar  6 12:30:34.065: //-1/06740132ACD3/CCAPI/cc_api_call_setup_ind_common:
   Incoming Dial-peer=901, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2185
*Mar  6 12:30:34.069: //-1/06740132ACD3/CCAPI/ccCheckClipClir:
*Mar  6 12:30:34.069: //2185/06740132ACD3/CCAPI/cc_api_call_setup_i
Router#nd_common:
   Set Up Event Sent;
*Mar  6 12:30:34.073: //2185/06740132ACD3/CCAPI/cc_process_call_setup_ind:
   Event=0x8395B168
*Mar  6 12:30:34.081: //2185/06740132ACD3/CCAPI/ccCallSetContext:
   Context=0x83C79730
*Mar  6 12:30:34.081: //2185/06740132ACD3/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 2185 with tag 901 to app "_ManagedAppProcess_Default"
*Mar  6 12:30:34.085: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <0001124957887603>;tag=16E04255-1BF7
Date: Wed, 06 Mar 2002 12:30:34 GMT
CSeq: 1 INVITE
Content-Length: 0
*Mar  6 12:30:34.089: //2185/06740132ACD3/CCAPI/ccCallProceeding:
*Mar  6 12:30:34.093: //2185/06740132ACD3/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=112, Params=0x83C6C520, Progress Indication=NULL(0)
*Mar  6 12:30:34.093: //2185/06740132ACD3/CCAPI/ccCheckClipClir:
*Mar  6 12:30:34.097: //2185/06740132ACD3/CCAPI/ccCallSetupRequest:
   Guid=06740132-EADE-11E1-ACD3-001A64C74ED8, Outgoing Dial-peer=112
*Mar  6 12:30:34.097: //2185/06740132ACD3/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=4957887603
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Mar  6 12:30:34.101: //2185/06740132ACD3/CCAPI/ccIFCallSetupRequestPrivate:
*Mar  6 12:30:34.101: //2186/06740132ACD3/CCAPI/ccIFCallSetupRequestPrivate:
*Mar  6 12:30:34.101: //2186/06740132ACD3/CCAPI/ccCallSetContext:
   Context=0x83C6C4D0
*Mar  6 12:30:34.101: //2185/06740132ACD3/CCAPI/ccSaveDialpeerTag:
*Mar  6 12:30:34.105: //2186/06740132ACD3/CCAPI/cc_api_call_proceeding:
*Mar  6 12:30:34.121: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bKA7A1A02
To: <4957887603>
Call-ID: CA189D55-303411D6-8891ED6C-C23DC168@10.0.99.29
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Remote-Party-ID: <4991589848>;party=calling;screen=no;privacy=off
Timestamp: 1015417834
Expires: 180
Content-Length: 240
v=0
o=CiscoSystemsSIP-GW-UserAgent 2388 334 IN IP4 10.0.99.29
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
m=audio 19236 RTP/AVP 8 101
c=IN IP4 10.0.99.29
a=fmtp:101 0-16
a=ptime:10
*Mar  6 12:30:34.125: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <4957887603>
CSeq: 101 INVITE
Contact: <4957887603>
Router#60>
Content-Length: 0
Router#
*Mar  6 12:30:38.087: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <4957887603>;tag=1351466003-3776044778-436225447-2287060836
CSeq: 101 INVITE
Content-Length:   239
v=0
o=- 1345477519 1345477519 IN IP4 10.0.99.111
s=-
t=0 0
m=audio 57620 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:10
a=sendrecv
*Mar  6 12:30:38.095: //2186/06740132ACD3/CCAPI/cc_api_event_indication:
   Event=132, Call Id=2186
*Mar  6 12:30:38.095: //2186/06740132ACD3/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=2186,
   Caps(Codec=0x0, Fax Rate=0x0, Vad=0x0,
   Modem=0x0, Codec Bytes=0, Signal Type=0)
*Mar  6 12:30:38.099: //2186/06740132ACD3/CCAPI/cc_api_caps_ind:
   Playout Max=0(ms), Fax Nom=0(ms))
*Mar  6 12:30:38.099: //2185/06740132ACD3/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=2185,
*Mar  6 12:30:38.099: //2186/06740132ACD3/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
*Mar  6 12:30:38.103: //2185/06740132ACD3/CCAPI/ccCallCutProgress:
*Mar  6 12:30:38.107: //2185/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x82BB84E8, callID1=0x889, callID2=0x88A, tag=0x0)
*Mar  6 12:30:38.107: //2185/06740132ACD3/CCAPI/ccConferenceCreate:
   Conference Id=0x82BB84E8, Call Id1=2185, Call Id2=2186, Tag=0x0
*Mar  6 12:30:38.107: ccConferenceCreate: ret1=0, codecMask1=2, bytes1=80, negot1=1
*Mar  6 12:30:38.107: //2185/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Mar  6 12:30:38.107: cc_api_get_xcode_stream : 4181
*Mar  6 12:30:38.107: //2185/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x3DB, Source Interface=0x83797348, Source Call Id=2185,
   Destination Call Id=2186, Disposition=0x0, Tag=0x0
*Mar  6 12:30:38.111: //2186/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Mar  6 12:30:38.111: cc_api_get_xcode_stream : 4181
*Mar  6 12:30:38.111: //2186/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x3DB, Source Interface=0x83797348, Source Call Id=2186,
   Destination Call Id=2185, Disposition=0x0, Tag=0x0
*Mar  6 12:30:38.111: //2185/06740132ACD3/CCAPI/cc_generic_bridge_done:
*Mar  6 12:30:38.115: //2185/06740132ACD3/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x3DB, Destination Call Id=2186)
*Mar  6 12:30:38.115: //2186/06740132ACD3/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x3DB, Destination Call Id=2185)
*Mar  6 12:30:38.115: //2185/06740132ACD3/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x3DB, Call Id1=2185, Call Id2=2186
*Mar  6 12:30:38.123: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Contact: <0001124957887603>
Content-Length: 255
v=0
o=CiscoSystemsSIP-GW-UserAgent 6399 483 IN IP4 10.0.99.29
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
m=audio 18296 RTP/AVP 8 101
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  6 12:30:38.139: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
*Mar  6 12:30:38.139: //2186/06740132ACD3/CCAPI/cc_api_call_alert:
*Mar  6 12:30:38.143: //2185/06740132ACD3/CCAPI/ccCallAlert:
*Mar  6 12:30:38.151: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Router#INFO, UPDATE, REGISTER
Content-Length: 0
Router#
*Mar  6 12:30:41.717: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length:   239
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:10
a=sendrecv
*Mar  6 12:30:41.725: //2186/06740132ACD3/CCAPI/cc_api_call_connected:
   Connection Handle=0
*Mar  6 12:30:41.729: //2185/06740132ACD3/CCAPI/ccCallConnect:
*Mar  6 12:30:41.741: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bKA7B25E2
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Mar  6 12:30:41.745: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Content-Length: 255
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
Router#
*Mar  6 12:30:41.749: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.0.99.121:5061;rport;branch=z9hG4bK-1645678603-3776044778-436261804-3629041508
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Router#
*Mar  6 12:30:46.902: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.0.99.100:5060;rport;branch=z9hG4bK-2417383963-3776044778-436225447-22870608361
Via: SIP/2.0/UDP 10.0.99.111:5061;rport=5061;branch=z9hG4bK-2417383963-3776044778-436225447-2287060836;received=10.0.99.111
From: <4957887603>;tag=1351466003-3776044778-436225447-2287060836
To: <4991589848>;tag=16E0428D-D2A
CSeq: 102 INVITE
Max-Forwards: 70
Content-Length:   193
v=0
o=- 1345477528 1345477528 IN IP4 10.0.99.111
s=-
t=0 0
m=image 57620 udptl t38
a=sendrecv
*Mar  6 12:30:46.910: //2185/06740132ACD3/CCAPI/ccGenerateToneInfo:
   Tone Direction=Sum Network, Params=0x0, Call Id=2185
*Mar  6 12:30:46.914: //2185/06740132ACD3/CCAPI/cc_api_remote_codec_dnld_done:
   Destination Interface=0x83797348, Destination Call Id=2185, Source Call Id=2186, Xmit Function=0x81AB0204
*Mar  6 12:30:46.914: //2186/06740132ACD3/CCAPI/cc_api_modify_media_ind:
   IFType=0x3, Source Call Id=0x88A, Destination Call Id=0x889,
   Codec=65536, Codec Bytes=-2086090616
*Mar  6 12:30:46.930: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.0.99.100:5060;rport;branch=z9hG4bK-2417383963-3776044778-436225447-22870608361,SIP/2.0/UDP 10.0.99.111:5061;rport=5061;branch=z9hG4bK-2417383963-3776044778-436225447-2287060836;received=10.0.99.111
Date: Wed, 06 Mar 2002 12:30:46 GMT
CSeq: 102 INVITE
Remote-Party-ID: <4991589848>;party=called;screen=no;privacy=off
Content-Length: 0
*Mar  6 12:30:46.934: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Content-Length: 150
v=0
o=CiscoSystemsSIP-GW-UserAgent 2388 335 IN IP4 10.0.99.29
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
m=image 19236 udptl t38
c=IN IP4 10.0.99.29
*Mar  6 12:30:46.942: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  6 12:30:46.950: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.0.99.100:5060;rport;branch=z9hG4bK-2800115483-3776044778-436225447-22870608361
Via: SIP/2.0/UDP 10.0.99.111:5061;rport=5061;branch=z9hG4bK-2800115483-3776044778-436225447-2287060836;received=10.0.99.111
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  6 12:30:47.427: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Content-Length: 255
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
Router#
*Mar  6 12:30:47.431: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  6 12:30:48.428: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 06 Mar 2002 12:30:47 GMT
CSeq: 1 INVITE
Supported: replaces
Content-Length: 255
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
Router#
*Mar  6 12:30:48.436: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Router#
*Mar  6 12:30:50.427: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 06 Mar 2002 12:30:48 GMT
CSeq: 1 INVITE
Supported: replaces
Content-Length: 255
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
Router#
*Mar  6 12:30:50.435: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Router#
*Mar  6 12:30:54.430: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 06 Mar 2002 12:30:50 GMT
CSeq: 1 INVITE
Supported: replaces
Content-Length: 255
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
Router#
*Mar  6 12:30:54.434: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Router#
*Mar  6 12:30:58.433: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 06 Mar 2002 12:30:54 GMT
CSeq: 1 INVITE
Supported: replaces
Content-Length: 255
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
Router#
*Mar  6 12:30:58.441: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Router#
*Mar  6 12:31:02.435: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 06 Mar 2002 12:30:58 GMT
CSeq: 1 INVITE
Supported: replaces
Content-Length: 255
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
Router#
*Mar  6 12:31:02.439: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Router#
*Mar  6 12:31:06.434: //2185/06740132ACD3/CCAPI/cc_api_call_disconnected:
   Cause Value=127, Interface=0x83797348, Call Id=2185
*Mar  6 12:31:06.438: //2185/06740132ACD3/CCAPI/ccConferenceDestroy:
   Conference Id=0x3DB, Tag=0x0
*Mar  6 12:31:06.438: //2185/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*Mar  6 12:31:06.438: //2186/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*Mar  6 12:31:06.438: //2185/06740132ACD3/CCAPI/cc_generic_bridge_done:
*Mar  6 12:31:06.442: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:4991589848@10.0.99.121:5061;user=phone SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bKA7CBEB
To: <4991589848>;tag=2395895558-3776044778-436261804-3629041508
Date: Wed, 06 Mar 2002 12:31:02 GMT
Max-Forwards: 70
Timestamp: 1015417866
CSeq: 101 BYE
Content-Length: 0
*Mar  6 12:31:06.450: //2185/06740132ACD3/CCAPI/ccCallDisconnect:
*Mar  6 12:31:06.450: //2186/06740132ACD3/CCAPI/ccCallDisconnect:
*Mar  6 12:31:06.454: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Content-Length: 0
*Mar  6 12:31:06.458: //2185/06740132ACD3/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x83797348, Tag=0x0, Call Id=2185,
*Mar  6 12:31:06.466: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bKA7D30E
Max-Forwards: 70
CSeq: 102 BYE
Content-Length: 0
*Mar  6 12:31:06.474: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
*Mar  6 12:31:06.474: //2186/06740132ACD3/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x83797348, Tag=0x0, Call Id=2186,
Router#
*Mar  6 12:31:06.478: //2186/06740132ACD3/CCAPI/cc_api_call_disconnect_done:
Router#
Very strange issue.
Can you add the full config and the output of "debug ccsip all"?
Regards.
Sure!
Router#
*Mar  7 02:47:00.253: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.121:5061
*Mar  7 02:47:00.253: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:00.257: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.0.99.121:5061;rport;branch=z9hG4bK-1962345899-3776009707-436262060-3629041508
From: <4991589848>;tag=46400939-3776009707-436262060-3629041508
Call-ID: ab05c434eb5511e1acd4001a64c74ed8@10.0.99.121
CSeq: 1 INVITE
Max-Forwards: 70
Cisco-Guid: 2868650854-3948220897-2899574810-1690783448
Category: 10
Content-Length:   313
v=0
o=- 1345528901 1345528901 IN IP4 10.0.99.221
s=-
t=0 0
m=audio 32510 RTP/AVP 8 0 18 4 96
a=fmtp:18 annexb=no
a=fmtp:4 annexa=yes
a=fmtp:96 0-15
a=sendrecv
*Mar  7 02:47:00.261: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5061
*Mar  7 02:47:00.261: //-1/AAFC2366ACD4/SIP/State/sipSPIChangeState: 0x83A98764 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
*Mar  7 02:47:00.261: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5060
*Mar  7 02:47:00.261: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar  7 02:47:00.269: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetGtdBody: No valid GTD body found.
*Mar  7 02:47:00.269: //-1/AAFC2366ACD4/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
*Mar  7 02:47:00.269: //-1/AAFC2366ACD4/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x83A98764 key=ab05c434eb5511e1acd4001a64c74ed8@10.0.99.1210001124957887603
*Mar  7 02:47:00.269: //-1/AAFC2366ACD4/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on carrier id
*Mar  7 02:47:00.269: //-1/AAFC2366ACD4/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: 0001124957887603
*Mar  7 02:47:00.269: //-1/AAFC2366ACD4/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 4991589848
*Mar  7 02:47:00.273: //-1/AAFC2366ACD4/SIP/Info/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name , number 4991589848, Calling oct3 0x00, oct_3a 0x80, Called number 0001124957887603
*Mar  7 02:47:00.273: //-1/AAFC2366ACD4/SIP/Info/sipSPIGetCallConfig: Peer tag 901 matched for incoming call
*Mar  7 02:47:00.273: //-1/AAFC2366ACD4/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 1
*Mar  7 02:47:00.277: //-1/AAFC2366ACD4/SIP/Info/sipSPIContinueNewMsgInvite: Calling name , number 4991589848, Calling oct3 0x00, oct_3a 0x80, ext_priv 0x00, Called number 0001124957887603, oct3 0x00
*Mar  7 02:47:00.277: //-1/AAFC2366ACD4/SIP/Info/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
*Mar  7 02:47:00.277: //-1/AAFC2366ACD4/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
*Mar  7 02:47:00.277: //2299/AAFC2366ACD4/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
*Mar  7 02:47:00.277: //2299/AAFC2366ACD4/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711alaw) Negotiation Successful on Static Payload for m-line 1
*Mar  7 02:47:00.277: //2299/AAFC2366ACD4/SIP/Info/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
*Mar  7 02:47:00.281: //2299/AAFC2366ACD4/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
*Mar  7 02:47:00.281: //2299/AAFC2366ACD4/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(96) could not be reserved.
*Mar  7 02:47:00.281: //2299/AAFC2366ACD4/SIP/Info/sipSPIDoDTMFRelayNegotiation: Requested DTMF-RELAY payload (96) is reserved by another application.
*Mar  7 02:47:00.281: //2299/AAFC2366ACD4/SIP/Info/sipSPIDoDTMFRelayNegotiation: Requested DTMF-RELAY option(s) not found in Preferred DTMF-RELAY option list!
*Mar  7 02:47:00.281: //2299/AAFC2366ACD4/SIP/Info/sipSPIStreamTypeAndDtmfRelay: DTMF Relay mode: Inband Voice
*Mar  7 02:47:00.281: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
*Mar  7 02:47:00.281: //2299/AAFC2366ACD4/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
*Mar  7 02:47:00.281: //2299/AAFC2366ACD4/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
*Mar  7 02:47:00.281: //2299/AAFC2366ACD4/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=8, codec_bytes=80, codec=g711alaw, dtmf_relay=inband-voice
        stream_type=voice-only (0), dest_ip_address=10.0.99.221, dest_port=32510
*Mar  7 02:47:00.285: //2299/AAFC2366ACD4/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Preferred Codec        : g711alaw, bytes :80
        Preferred  DTMF relay  : rtp-nte
        Preferred NTE payload  : 101
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : No
        New Media              : No
        DSP DNLD Reqd          : No
*Mar  7 02:47:00.285: //2299/AAFC2366ACD4/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Mar  7 02:47:00.285: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2299 peer 0 flags 0x201
*Mar  7 02:47:00.285: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2299, sdp 0x82BDF4AC channels 0x83A9A314
*Mar  7 02:47:00.285: //2299/AAFC2366ACD4/SIP/Info/copy_channels:
callId 2299 size 0 ptr 0x83638200)
SIP: (2299) Attribute ptime, level 1 instance 1 not found.
Hndl ptype 8 mline 1
*Mar  7 02:47:00.285: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711alaw
*Mar  7 02:47:00.285: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :80, ptime: 10
*Mar  7 02:47:00.289: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=0,stream->negotiated_codec_bytes=80, coverted ptime=10 stream->mline_index=1, media_ndx=1
Adding codec 6 ptype 8 time 10, bytes 80  as channel 0 mline 1 ss 0 10.0.99.221:32510
Hndl ptype 0 mline 1
*Mar  7 02:47:00.289: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
*Mar  7 02:47:00.289: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation NOT done, get ptime from sdp: ptime=0, media_ndx=1
*Mar  7 02:47:00.289: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :0, codecbytes: 0
*Mar  7 02:47:00.289: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Codec bytes 0, use default packet rate 160
*Mar  7 02:47:00.293: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 0, bytes 160  as channel 1 mline 1 ss 0 10.0.99.221:32510
Hndl ptype 18 mline 1
*Mar  7 02:47:00.293: //2299/AAFC2366ACD4/SIP/Media/sipSPISelectCodecVersion: Codec (g729r8) is not in preferred list
*Mar  7 02:47:00.293: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: An exact codec match not configured, using interoperable codec g729r8 pre-ietf
*Mar  7 02:47:00.293: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g729r8 pre-ietf
*Mar  7 02:47:00.293: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation NOT done, get ptime from sdp: ptime=0, media_ndx=1
*Mar  7 02:47:00.293: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g729r8 pre-ietf ptime :0, codecbytes: 0
*Mar  7 02:47:00.293: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Codec bytes 0, use default packet rate 20
Adding codec 0 ptype 18 time 0, bytes 20  as channel 2 mline 1 ss 0 10.0.99.221:32510
*Mar  7 02:47:00.297: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 4 mline 1
*Mar  7 02:47:00.297: //2299/AAFC2366ACD4/SIP/Media/sipSPISelectCodecVersion: Codec (g723ar63) is not in preferred list
*Mar  7 02:47:00.297: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: An exact codec match not configured, using interoperable codec g729r8 pre-ietf
*Mar  7 02:47:00.297: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g729r8 pre-ietf
*Mar  7 02:47:00.297: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation NOT done, get ptime from sdp: ptime=0, media_ndx=1
*Mar  7 02:47:00.297: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g729r8 pre-ietf ptime :0, codecbytes: 0
*Mar  7 02:47:00.297: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Codec bytes 0, use default packet rate 20
Adding codec 0 ptype 4 time 0, bytes 20  as channel 3 mline 1 ss 0 10.0.99.221:32510
*Mar  7 02:47:00.301: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 96 mline 1
*Mar  7 02:47:00.301: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report initial call media
*Mar  7 02:47:00.301: //2299/AAFC2366ACD4/SIP/Info/copy_channels:
callId 2299 size 296 ptr 0x8363A2FC)
*Mar  7 02:47:
Router#00.301: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_report_media_to_peer:
CCSIP: Unable to report channel ind
*Mar  7 02:47:00.301: //2299/AAFC2366ACD4/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Stream type            : voice-only
          Media line             : 1
          State                  : STREAM_ADDING (2)
          Callid                 : -1
          Negotiated Codec       : g711alaw, bytes :80
          Negotiated DTMF relay  : inband-voice
          Negotiated NTE payload : 0
          Negotiated CN payload  : 0
          Media Srce Addr/Port   : 10.0.99.29:0
          Media Dest Addr/Port   : 10.0.99.221:32510
*Mar  7 02:47:00.301: //2299/AAFC2366ACD4/SIP/Info/sipSPIHandleInviteMedia:
Preferred  DTMF relay 1 : 6
Preferred  DTMF relay 2 : 0
Negotiated DTMF relay   : 0
Preferred and Negotiated NTE payloads: 101 0
Preferred and Negotiated NSE payloads: 100 0
Preferred and Negotiated Modem Relay: 0 0
Preferred and Negotiated Modem Relay GwXid: 1 0
*Mar  7 02:47:00.301: //2299/AAFC2366ACD4/SIP/Info/sipSPIDoQoSNegotiation: SDP body with media description
*Mar  7 02:47:00.305: //2299/AAFC2366ACD4/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
*Mar  7 02:47:00.305: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 17342 for stream 1
*Mar  7 02:47:00.305: //2299/AAFC2366ACD4/SIP/Info/sipSPIUpdateSrcSdpFixedPart: Reserving rtp port for stream 1, src_port=17342
*Mar  7 02:47:00.305: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
*Mar  7 02:47:00.305: //2299/AAFC2366ACD4/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 17342
*Mar  7 02:47:00.309: //2299/AAFC2366ACD4/SIP/Info/sipSPIAddBillingInfoToCcb: sipCallId for billing records = ab05c434eb5511e1acd4001a64c74ed8@10.0.99.121
*Mar  7 02:47:00.309: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_store_channel_info: Store channelInfo in CallInfo
*Mar  7 02:47:00.309: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateRawMsg: No GTD passed.
*Mar  7 02:47:00.309: //2299/AAFC2366ACD4/SIP/Info/sipSPIContinueNewMsgInvite: ccsip_api_call_setup_ind returned: SIP_SUCCESS
*Mar  7 02:47:00.309: //2299/AAFC2366ACD4/SIP/Info/sipSPIUaddCcbToUASRespTable: ****Adding to UAS Response table.
*Mar  7 02:47:00.309: //2299/AAFC2366ACD4/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x83A98764 key=ab05c434eb5511e1acd4001a64c74ed8@10.0.99.12119F059BD-1F7C
*Mar  7 02:47:00.313: //2299/AAFC2366ACD4/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 8FB to table
*Mar  7 02:47:00.313: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: msg=0x83C22C80, addr=10.0.99.121, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Mar  7 02:47:00.317: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:00.317: //2299/AAFC2366ACD4/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:00.317: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C22C80, addr=10.0.99.121, port=5061, connId=0 for UDP
*Mar  7 02:47:00.317: //2299/AAFC2366ACD4/SIP/State/sipSPIChangeState: 0x83A98764 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_RECD_INVITE, SUBSTATE_NONE)
*Mar  7 02:47:00.317: //2299/AAFC2366ACD4/SIP/Info/sipSPIProcessContactInfo: Previous Hop 10.0.99.121:5061
*Mar  7 02:47:00.321: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
*Mar  7 02:47:00.329: //2300/000000000000/SIP/State/sipSPIChangeState: 0x83A87C30 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
*Mar  7 02:47:00.329: //2300/000000000000/SIP/Info/ccsip_call_setup_request:
This a IPIP call: Chan 0, codec 6 channel 32510, ip A0063DD:32510  params 0x83C958D4 caps 0x83C698A4
This a IPIP call: Chan 1, codec 5 channel 32510, ip A0063DD:32510  params 0x83C958D4 caps 0x83C698A4
This a IPIP call: Chan 2, codec 0 channel 32510, ip A0063DD:32510  params 0x83C958D4 caps 0x83C698A4
This a IPIP call: Chan 3, codec 0 channel 32510, ip A0063DD:32510  params 0x83C958D4 caps 0x83C698A4
*Mar  7 02:47:00.329: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
*Mar  7 02:47:00.329: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler:
*Mar  7 02:47:00.329: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 138)
*Mar  7 02:47:00.333: //2299/AAFC2366ACD4/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 2300 chans 0x83008EB8 event 138 flags 0x10020038 0x601 data 0x83008EB8
ccsip_event_handler: CC_EV_H245_SET_MODE: peer ID 2300 chans 0x83008EB8 event 138 flags  0x10020038 0x601 data 0x83008EB8
ccsip_event_handler: CC_EV_H245_SET_MODE: peer ID 2300 chans 0x83008EB8 event 138 flags 0x10020038 0x601 data 0x83008EB8, type = 3
*Mar  7 02:47:00.333: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
*Mar  7 02:47:00.333: //2300/000000000000/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 8FC to table
*Mar  7 02:47:00.337: //2300/000000000000/SIP/Info/act_idle_continue_call_setup:
*Mar  7 02:47:00.337: //2300/000000000000/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
*Mar  7 02:47:00.337: //2300/000000000000/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
*Mar  7 02:47:00.337: //2300/000000000000/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 1
*Mar  7 02:47:00.337: //2300/000000000000/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 2300, channels 0x82BCEFE8 caps 0x83C698A4
pref dtmf 96
*Mar  7 02:47:00.341: //2300/000000000000/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
retreive codec 6 ptype 255 time 0 bytes 0
retreive codec 5 ptype 255 time 0 bytes 0
retreive codec 0 ptype 255 time 0 bytes 0
*Mar  7 02:47:00.341: //2300/000000000000/SIP/Info/sipSPIValidateGtd: No rawMsg from CCAPI
*Mar  7 02:47:00.341: //2300/000000000000/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
*Mar  7 02:47:00.341: //2300/000000000000/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
*Mar  7 02:47:00.345: //2300/000000000000/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x83A87C30 key=6EAE04D4-30AC11D6-8903ED6C-C23DC168@10.0.99.29
*Mar  7 02:47:00.345: //2300/000000000000/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = 6EAE04D4-30AC11D6-8903ED6C-C23DC168@10.0.99.29
*Mar  7 02:47:00.345: //2300/000000000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Mar  7 02:47:00.345: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 19298 for stream 1
*Mar  7 02:47:00.345: //2300/000000000000/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
*Mar  7 02:47:00.349: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :80, ptime: 10
*Mar  7 02:47:00.349: //2300/000000000000/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
*Mar  7 02:47:00.349: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.0.99.100,Port 5060, Transport 1, SentBy Port 5060
*Mar  7 02:47:00.349: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar  7 02:47:00.349: //2300/000000000000/SIP/Event/sipSPICreateRpid: Received Octet3A=0x80 -> Setting ;screen=no ;privacy=off
*Mar  7 02:47:00.357: //2300/000000000000/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
*Mar  7 02:47:00.357: //2300/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Mar  7 02:47:00.357: //2300/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x83C24390, addr=10.0.99.100, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x80AAE060
*Mar  7 02:47:00.357: //2300/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:00.357: //2300/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:00.357: //2300/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x83C24390
*Mar  7 02:47:00.357: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C24390, addr=10.0.99.100, port=5060, connId=1 for UDP
*Mar  7 02:47:00.357: //2300/000000000000/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
*Mar  7 02:47:00.357: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
*Mar  7 02:47:00.361: //2300/000000000000/SIP/State/sipSPIChangeState: 0x83A87C30 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_SENT_INVITE, SUBSTATE_NONE)
*Mar  7 02:47:00.361: //2300/000000000000/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
*Mar  7 02:47:00.361: //2300/000000000000/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 2300) to the VOIP RTP library
*Mar  7 02:47:00.361: //2300/000000000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Mar  7 02:47:00.361: //2300/000000000000/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Mar  7 02:47:00.361: //2300/000000000000/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.0.99.29, lport = 19298, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
        src_callid = 2300, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
        media_ip_addr = 0.0.0.0
*Mar  7 02:47:00.361: //2300/000000000000/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
*Mar  7 02:47:00.365: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Tryin
Router#g
To: <0001124957887603>;tag=19F059BD-1F7C
Date: Thu, 07 Mar 2002 02:47:00 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 INVITE
Allow-Events: telephone-event
Content-Length: 0
*Mar  7 02:47:00.369: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bKB0C23C0
To: <4957887603>
Call-ID: 6EAE04D4-30AC11D6-8903ED6C-C23DC168@10.0.99.29
Supported: 100rel,timer,replaces
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1015469220
Expires: 180
Content-Type: application/sdp
Content-Length: 241
v=0
o=CiscoSystemsSIP-GW-UserAgent 5758 6866 IN IP4 10.0.99.29
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
m=audio 19298 RTP/AVP 8 101
c=IN IP4 10.0.99.29
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:10
*Mar  7 02:47:00.373: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.100:5060
*Mar  7 02:47:00.373: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:00.377: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <4957887603>
CSeq: 101 INVITE
Server: MERA MVTS3G v.4.4.0-15
Content-Length: 0
*Mar  7 02:47:00.377: //2300/000000000000/SIP/State/sipSPIChangeState: 0x83A87C30 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
Router#
*Mar  7 02:47:04.015: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.100:5060
*Mar  7 02:47:04.015: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:04.015: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <4957887603>;tag=343429304-3776009707-436225447-2287060836
CSeq: 101 INVITE
Content-Length:   239
v=0
o=- 1345528905 1345528905 IN IP4 10.0.99.111
s=-
c=IN IP4 10.0.99.111
t=0 0
m=audio 26272 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:10
a=sendrecv
a=silenceSupp:off - - - -
*Mar  7 02:47:04.019: //2300/000000000000/SIP/Info/HandleSIP1xxSessionProgress: Content-Disposition NOT received in 18x response - using default Content-Disposition values
*Mar  7 02:47:04.019: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetGtdBody: No valid GTD body found.
*Mar  7 02:47:04.023: //2300/000000000000/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
*Mar  7 02:47:04.023: //2300/000000000000/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711alaw) Negotiation Successful on Static Payload for m-line 1
*Mar  7 02:47:04.023: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711alaw ptime :10, codecbytes: 80
*Mar  7 02:47:04.023: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :80, ptime: 10
*Mar  7 02:47:04.023: //2300/000000000000/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:10, Negotiated ptime:10 Negotiated codec bytes: 80 for codec g711alaw
*Mar  7 02:47:04.027: //2300/000000000000/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
*Mar  7 02:47:04.027: //2300/000000000000/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved.
*Mar  7 02:47:04.027: //2300/000000000000/SIP/Info/sipSPIDoDTMFRelayNegotiation: Payload type (101) is reserved for requested dtmf relay mode.
*Mar  7 02:47:04.027: //2300/000000000000/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
*Mar  7 02:47:04.027: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
*Mar  7 02:47:04.027: //2300/000000000000/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
*Mar  7 02:47:04.027: //2300/000000000000/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
*Mar  7 02:47:04.027: //2300/000000000000/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=8, codec_bytes=80, codec=g711alaw, dtmf_relay=rtp-nte
        stream_type=voice+dtmf (1), dest_ip_address=10.0.99.111, dest_port=26272
*Mar  7 02:47:04.031: //2300/000000000000/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : No
        New Media              : No
        DSP DNLD Reqd          : No
*Mar  7 02:47:04.031: //2300/000000000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Mar  7 02:47:04.031: //2300/000000000000/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2300 peer 2299 flags 0x7
*Mar  7 02:47:04.031: //2300/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2300, sdp 0x838B9CDC channels 0x83A897E0
*Mar  7 02:47:04.031: //2300/000000000000/SIP/Info/copy_channels:
callId 2300 size 296 ptr 0x836371EC)
*Mar  7 02:47:04.031: //2300/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711alaw
*Mar  7 02:47:04.031: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :80, ptime: 10
*Mar  7 02:47:04.035: //2300/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=10,stream->negotiated_codec_bytes=80, coverted ptime=10 stream->mline_index=1, media_ndx=1
Adding codec 6 ptype 8 time 10, bytes 80  as channel 0 mline 1 ss 1 10.0.99.111:26272
Hndl ptype 101 mline 1
*Mar  7 02:47:04.035: //2300/000000000000/SIP/Info/sipSPI_ipip_report_media_to_peer:
*Mar  7 02:47:04.035: //2300/000000000000/SIP/Info/copy_channels:
callId 2300 size 80 ptr 0x82BFC918)
*Mar  7 02:47:04.035: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler:
*Mar  7 02:47:04.035: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 132)
*Mar  7 02:47:04.035: //2299/AAFC2366ACD4/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 2300 chans 0x82BFC918 event 132 flags 0x10020038 0x403 data 0x82BFC918
*Mar  7 02:47:04.039: //2299/AAFC2366ACD4/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_IND: peer ID 2300  chans 0x82BFC918 event 132 flags 0x10020038 0x403 data 0x82BFC918
*Mar  7 02:47:04.039: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
ccsip_event_handler: set event->type = SIPSPI_EV_CC_NEW_MEDIA!: peer ID 2300 chans 0x82BFC918 event 132 flags 0x10020038 0x403 data 0x82BFC918
*Mar  7 02:47:04.039: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
*Mar  7 02:47:04.039: //2299/AAFC2366ACD4/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=-1, current_seq_num=0xE46
*Mar  7 02:47:04.039: //2299/AAFC2366ACD4/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=-1, current_seq_num=0x0
*Mar  7 02:47:04.039: //2299/AAFC2366ACD4/SIP/Info/ccsip_caps_ind: Load DSP with negotiated codec: g711alaw, Bytes=80
*Mar  7 02:47:04.039: //2299/AAFC2366ACD4/SIP/Info/ccsip_caps_ind: Set forking flag to 0x3133
*Mar  7 02:47:04.039: //2299/AAFC2366ACD4/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_INBAND_VOICE_AND_OOB
*Mar  7 02:47:04.043: //2299/AAFC2366ACD4/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=1, from CLI config=0
*Mar  7 02:47:04.043: //2299/AAFC2366ACD4/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
*Mar  7 02:47:04.043: //2299/AAFC2366ACD4/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
*Mar  7 02:47:04.043: //2299/AAFC2366ACD4/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
*Mar  7 02:47:04.043: //2299/AAFC2366ACD4/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
*Mar  7 02:47:04.043: //2299/AAFC2366ACD4/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
*Mar  7 02:47:04.043: //2299/AAFC2366ACD4/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
*Mar  7 02:47:04.043: //2299/AAFC2366ACD4/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
caps.stream_count=0,caps.stream[0].stream_type=0xFFFF, caps.stream_list.xmitFunc=
*Mar  7 02:47:04.047: //2299/AAFC2366ACD4/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
*Mar  7 02:47:04.047: //2299/AAFC2366ACD4/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
*Mar  7 02:47:04.047: //2299/AAFC2366ACD4/SIP/Info/ccsip_caps_ind: Load DSP with codec : g711alaw, Bytes=80
*Mar  7 02:47:04.047: //2299/AAFC2366ACD4/SIP/Info/ccsip_caps_ind: ccsip_caps_ind: ccb->flags_ipip = 0x403
*Mar  7 02:47:04.047: //2300/000000000000/SIP/Info/ccsip_caps_ack: Set forking flag to 0x0
*Mar  7 02:47:04.047: //2300/000000000000/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Stream type            : voice+dtmf
          Media line             : 1
          Callid                 : 2300
          Negotiated DTMF relay  : rtp-nte
          Negotiated NTE payload : 101
          Media Srce Addr/Port   : 10.0.99.29:19298
          Media Dest Addr/Port   : 10.0.99.111:26272
*Mar  7 02:47:04.047: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateRawMsg: No GTD passed.
*Mar  7 02:47:04.047: //2300/000000000000/SIP/Info/HandleSIP1xxSessionProgress: ccsip_api_call_cut_progress returned: SIP_SUCCESS
*Mar  7 02:47:04.051: //2300/000000000000/SIP/State/sipSPIChangeState: 0x83A87C30 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
*Mar  7 02:47:04.051: //2300/000000000000/SIP/Info/HandleSIP1xxSessionProgress: Transaction Complete. Lock on Facilities released.
*Mar  7 02:47:04.051: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 2299 ft: 1, inc 8, 10.0.99.111:26272, codec 6
*Mar  7 02:47:04.051: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 2299, channels 0x82BFC918 caps 0x8363720C
pref dtmf 101
*Mar  7 02:47:04.055: //2299/AAFC2366ACD4/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
nego mline 1 dtmf 101 ss 1 ret 0
retreive codec 6 ptype 255 time 0 bytes 80
*Mar  7 02:47:04.055: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
*Mar  7 02:47:04.055: //2299/AAFC2366ACD4/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 17342
*Mar  7 02:47:04.055: //2299/AAFC2366ACD4/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
*Mar  7 02:47:04.055: //2299/AAFC2366ACD4/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
*Mar  7 02:47:04.059: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROGRESS
Router#Mar  7 02:47:04.059: //2299/AAFC2366ACD4/SIP/Info/ccsip_bridge: confID = 1038, srcCallID = 2299, dstCallID = 2300
*Mar  7 02:47:04.059: //2299/AAFC2366ACD4/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 2299/2300
*Mar  7 02:47:04.059: //2299/AAFC2366ACD4/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=-1, new streamcallid=2299
*Mar  7 02:47:04.059: //2299/AAFC2366ACD4/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
*Mar  7 02:47:04.059: //2299/AAFC2366ACD4/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 2299) to the VOIP RTP library
*Mar  7 02:47:04.059: //2299/AAFC2366ACD4/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Mar  7 02:47:04.063: //2299/AAFC2366ACD4/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Mar  7 02:47:04.063: //2299/AAFC2366ACD4/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.0.99.29, lport = 17342, raddr = 10.0.99.221, rport=32510, do_rtcp=TRUE
        src_callid = 2299, dest_callid = 2300, stream type = voice+dtmf, stream direction = SENDRECV
        media_ip_addr = 10.0.99.221
*Mar  7 02:47:04.063: //2299/AAFC2366ACD4/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
*Mar  7 02:47:04.063: //2299/AAFC2366ACD4/SIP/Info/sipSPIUpdateRtcpSession: Process Media changes is still pending.
*Mar  7 02:47:04.063: //2299/AAFC2366ACD4/SIP/Media/sipSPIGetNewLocalMediaDirection:
        New Remote Media Direction = SENDRECV
        Present Local Media Direction = SENDRECV
        New Local Media Direction = SENDRECV
        retVal = 0
*Mar  7 02:47:04.067: //2300/000000000000/SIP/Info/ccsip_bridge: confID = 1038, srcCallID = 2300, dstCallID = 2299
*Mar  7 02:47:04.067: //2300/000000000000/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 2300/2299
*Mar  7 02:47:04.067: //2300/000000000000/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=2300, new streamcallid=2300
*Mar  7 02:47:04.067: //2300/000000000000/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
*Mar  7 02:47:04.067: //2300/000000000000/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 2300) to the VOIP RTP library
*Mar  7 02:47:04.067: //2300/000000000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Mar  7 02:47:04.067: //2300/000000000000/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Mar  7 02:47:04.067: //2300/000000000000/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.0.99.29, lport = 19298, raddr = 10.0.99.111, rport=26272, do_rtcp=TRUE
        src_callid = 2300, dest_callid = 2299, stream type = voice+dtmf, stream direction = SENDRECV
        media_ip_addr = 10.0.99.111
*Mar  7 02:47:04.071: //2300/000000000000/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
*Mar  7 02:47:04.071: //2300/000000000000/SIP/Media/sipSPIGetNewLocalMediaDirection:
        retVal = 0
*Mar  7 02:47:04.075: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.100:5060
*Mar  7 02:47:04.075: //2299/AAFC2366ACD4/SIP/Info/sipSPIValidateGtd: No rawMsg from CCAPI
*Mar  7 02:47:04.075: //2299/AAFC2366ACD4/SIP/Info/sipSPISendInviteResponse183: Session Type is Media/Qos/Security/RTR SDP body is attached
*Mar  7 02:47:04.079: //2299/AAFC2366ACD4/SIP/Transport/sipSPISendInviteResponse: Sending 183 Response to the Transport Layer
*Mar  7 02:47:04.083: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: msg=0x83C22920, addr=10.0.99.121, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x80AAE960
*Mar  7 02:47:04.083: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:04.083: //2299/AAFC2366ACD4/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:04.083: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C22920, addr=10.0.99.121, port=5061, connId=0 for UDP
*Mar  7 02:47:04.083: //2299/AAFC2366ACD4/SIP/Info/sentInviteResponse18x: Sent a 18x Response
*Mar  7 02:47:04.083: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:04.087: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
*Mar  7 02:47:04.087: //2300/000000000000/SIP/Info/ccsip_api_call_alert: SDP Body either absent or ignored in 180 RINGING:- If media cut through is not done in 18x will wait for 200 OK to do negotiation.
*Mar  7 02:47:04.087: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateRawMsg: No GTD passed.
*Mar  7 02:47:04.087: //2300/000000000000/SIP/Info/HandleSIP1xxRinging: ccsip_api_call_alert returned: SIP_SUCCESS
*Mar  7 02:47:04.091: //2300/000000000000/SIP/State/sipSPIChangeState: 0x83A87C30 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
*Mar  7 02:47:04.091: //2300/000000000000/SIP/Info/HandleSIP1xxRinging: Transaction Complete. Lock on Facilities released.
*Mar  7 02:47:04.095: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
CSeq: 1 INVITE
Content-Disposition: session;handling=required
Content-Length: 256
v=0
o=CiscoSystemsSIP-GW-UserAgent 6669 2084 IN IP4 10.0.99.29
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
m=audio 17342 RTP/AVP 8 101
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  7 02:47:04.099: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
*Mar  7 02:47:04.099: //2299/AAFC2366ACD4/SIP/Info/sipSPIValidateGtd: No rawMsg from CCAPI
*Mar  7 02:47:04.103: //2299/AAFC2366ACD4/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
*Mar  7 02:47:04.103: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: msg=0x83C22920, addr=10.0.99.121, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x80AAE960
*Mar  7 02:47:04.103: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:04.107: //2299/AAFC2366ACD4/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:04.107: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C22920, addr=10.0.99.121, port=5061, connId=0 for UDP
*Mar  7 02:47:04.107: //2299/AAFC2366ACD4/SIP/Info/sentInviteResponse18x: Sent a 18x Response
*Mar  7 02:47:04.107: //2299/AAFC2366ACD4/SIP/State/sipSPIChangeState: 0x83A98764 : State change from (STATE_RECD_INVITE, SUBSTATE_NONE)  to (STATE_SENT_ALERTING, SUBSTATE_NONE)
*Mar  7 02:47:04.111: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Content-Length: 0
Router#
*Mar  7 02:47:07.697: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.100:5060
*Mar  7 02:47:07.697: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:07.701: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow: ACK, BYE, CANCEL, INFO, INVITE, OPTIONS, REFER, REGISTER, SUBSCRIBE, UPDATE
X-mera-expires: 86460
Content-Length:   239
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:10
a=sendrecv
*Mar  7 02:47:07.705: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetGtdBody: No valid GTD body found.
*Mar  7 02:47:07.705: //2300/000000000000/SIP/Info/sipSPIhandle200OKInvite: Transaction active. Facilities will be queued.
*Mar  7 02:47:07.705: //2300/000000000000/SIP/Info/sipSPIhandle200OKInvite: *** This ccb is the parent
*Mar  7 02:47:07.709: //2300/000000000000/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
*Mar  7 02:47:07.709: //2300/000000000000/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711alaw) Negotiation Successful on Static Payload for m-line 1
*Mar  7 02:47:07.709: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711alaw ptime :10, codecbytes: 80
*Mar  7 02:47:07.709: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :80, ptime: 10
*Mar  7 02:47:07.709: //2300/000000000000/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:10, Negotiated ptime:10 Negotiated codec bytes: 80 for codec g711alaw
*Mar  7 02:47:07.709: //2300/000000000000/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
*Mar  7 02:47:07.713: //2300/000000000000/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
*Mar  7 02:47:07.713: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
*Mar  7 02:47:07.713: //2300/000000000000/SIP/Info/sip_do_nse_negotiation: Remote NSE payload = local one = 0, Use it
*Mar  7 02:47:07.713: //2300/000000000000/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
*Mar  7 02:47:07.713: //2300/000000000000/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
*Mar  7 02:47:07.713: //2300/000000000000/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
*Mar  7 02:47:07.713: //2300/000000000000/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=26272 new=26272
*Mar  7 02:47:07.713: //2300/000000000000/SIP/Media/sipSPIGetNewLocalMediaDirection:
        retVal = 0
*Mar  7 02:47:07.717: //2300/000000000000/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=No CAPS_CHANGE=No
*Mar  7 02:47:07.717: //2300/000000000000/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=No DSPDNLD_REQD=No IPIP_MEDIA=No
*Mar  7 02:47:07.717: //2300/000000000000/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : Yes
        New Media              : No
        DSP DNLD Reqd          : No
*Mar  7 02:47:07.717: //2300/000000000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Mar  7 02:47:07.717: //2300/000000000000/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2300 peer 2299 flags 0x407
*Mar  7 02:47:07.717: //2300/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2300, sdp 0x833FA5D8 channels 0x83A897E0
*Mar  7 02:47:07.717: //2300/000000000000/SIP/Info/copy_channels:
callId 2300 size 80 ptr 0x82BF44E0)
*Mar  7 02:47:07.721: //2300/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
*Mar  7 02:47:07.721: //2300/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711alaw
*Mar  7 02:47:07.721: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :80, ptime: 10
*Mar  7 02:47:07.721: //2300/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=10,stream->negotiated_codec_bytes=80, coverted ptime=10 stream->mline_index=1, media_ndx=1
*Mar  7 02:47:07.725: //2300/000000000000/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Media line             : 1
          State                  : STREAM_ACTIVE (5)
          Callid                 : 2300
*Mar  7 02:47:07.725: //2300/000000000000/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
*Mar  7 02:47:07.725: //2300/000000000000/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connect_media returned: SIP_SUCCESS
*Mar  7 02:47:07.725: //2300/000000000000/SIP/State/sipSPIChangeState: 0x83A87C30 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
*Mar  7 02:47:07.725: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateRawMsg: No GTD passed.
*Mar  7 02:47:07.725: //2300/000000000000/SIP/Info/sipSPICreateAndStartRtpTimer:
*Mar  7 02:47:07.725: //2300/000000000000/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
*Mar  7 02:47:07.725: //2300/000000000000/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connected returned: SIP_SUCCESS
*Mar  7 02:47:07.729: //2300/000000000000/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
*Mar  7 02:47:07.729: //2300/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Mar  7 02:47:07.729: //2300/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x83C22C80, addr=10.0.99.100, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x80AAF6C8
*Mar  7 02:47:07.733: //2300/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:07.733: //2300/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:07.733: //2300/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x83C22C80
*Mar  7 02:47:07.733: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C22C80, addr=10.0.99.100, port=5060, connId=1 for UDP
*Mar  7 02:47:07.733: //2300/000000000000/SIP/State/sipSPIChangeState: 0x83A87C30 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
*Mar  7 02:47:07.733: //2300/000000000000/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x83A87C30
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 4991589848
Called Number            : 4957887603
Source IP Address (Sig  ): 10.0.99.29
Destn SIP Req Addr:Port  : 10.0.99.100:5060
Destn SIP Resp Addr:Port : 10.0.99.100:5060
Destination Name         : 10.0.99.100
*Mar  7 02:47:07.733: //2300/000000000000/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec Bytes   : 80
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101
Source IP Address (Media): 10.0.99.29
Source IP Port    (Media): 19298
Destn  IP Address (Media): 10.0.99.111
Destn  IP Port    (Media): 26272
Orig Destn IP Address:Port (Media): 0.0.0.0:0
*Mar  7 02:47:07.737: //2300/000000000000/SIP/Info/sipSPICallActive: Transaction Complete. Lock on Facilities released.
*Mar  7 02:47:07.737: //2300/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Mar  7 02:47:07.737: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_CONNECT
*Mar  7 02:47:07.745: //2299/AAFC2366ACD4/SIP/Info/sipSPIValidateGtd: No rawMsg from CCAPI
*Mar  7 02:47:07.749: //2299/AAFC2366ACD4/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Mar  7 02:47:07.749: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: msg=0x83C23970, addr=10.0.99.121, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x80AAEC48
*Mar  7 02:47:07.749: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:07.749: //2299/AAFC2366ACD4/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:07.749: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C23970, addr=10.0.99.121, port=5061, connId=0 for UDP
*Mar  7 02:47:07.753: //2299/AAFC2366ACD4/SIP/Info/sentInviteResponse200: Sent 200Ok for Invite in state STATE_SENT_ALERTING
*Mar  7 02:47:07.753: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteResponse200: Transaction active. Facilities will be queued.
*Mar  7 02:47:07.753: //2299/AAFC2366ACD4/SIP/State/sipSPIChangeState: 0x83A98764 : State change from (STATE_SENT_ALERTING, SUBSTATE_NONE)  to (STATE_SENT_SUCCESS, SUBSTATE_NONE)
*Mar  7 02:47:07.753: //2299/AAFC2366ACD4/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Mar  7 02:47:07.753: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:4957
Router#887603@10.0.99.100:5060 SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bKB0D1D83
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Mar  7 02:47:07.757: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Content-Length: 256
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  7 02:47:07.765: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.121:5061
*Mar  7 02:47:07.765: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:07.765: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0001124957887603@10.0.99.29:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.99.121:5061;rport;branch=z9hG4bK-3701309359-3776009707-436262060-3629041508
CSeq: 1 ACK
Max-Forwards: 70
User-Agent: MERA MVTS3G v.4.4.0-15
Content-Length: 0
*Mar  7 02:47:07.765: //2299/AAFC2366ACD4/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x83A98764
*Mar  7 02:47:07.769: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5060
*Mar  7 02:47:07.769: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar  7 02:47:07.773: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5061
*Mar  7 02:47:07.773: //2299/AAFC2366ACD4/SIP/Info/act_sentsucc_new_message_request: Transaction Complete. Lock on Facilities released.
*Mar  7 02:47:07.773: //2299/AAFC2366ACD4/SIP/State/sipSPIChangeState: 0x83A98764 : State change from (STATE_SENT_SUCCESS, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
*Mar  7 02:47:07.773: //2299/AAFC2366ACD4/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x83A98764
Called Number            : 0001124957887603
Destn SIP Req Addr:Port  : 10.0.99.121:5061
Destn SIP Resp Addr:Port : 10.0.99.121:5061
Destination Name         : 10.0.99.121
*Mar  7 02:47:07.773: //2299/AAFC2366ACD4/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 17342
Destn  IP Address (Media): 10.0.99.221
Destn  IP Port    (Media): 32510
*Mar  7 02:47:07.777: //2299/AAFC2366ACD4/SIP/Info/sipSPICreateAndStartRtpTimer:
*Mar  7 02:47:07.777: //2299/AAFC2366ACD4/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
*Mar  7 02:47:07.777: //2299/AAFC2366ACD4/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 10.0.99.221, RTCP Type 3
*Mar  7 02:47:07.777: //2299/AAFC2366ACD4/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
Router#
*Mar  7 02:47:11.019: //2298/000000000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
*Mar  7 02:47:11.019: //2298/000000000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x83AA2014 key=61A05BB1-30AC11D6-8901ED6C-C23DC168@10.0.99.29
*Mar  7 02:47:11.019: //2298/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Mar  7 02:47:11.019: //2298/AB2B8EB2A745/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 83AA2014
Router#
*Mar  7 02:47:12.898: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.100:5060
*Mar  7 02:47:12.898: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:12.898: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:4991589848@10.0.99.29:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.99.100:5060;rport;branch=z9hG4bK-1580058559-3776009707-436225447-22870608361
Via: SIP/2.0/UDP 10.0.99.111:5061;rport=5061;branch=z9hG4bK-1580058559-3776009707-436225447-2287060836;received=10.0.99.111
From: <4957887603>;tag=343429304-3776009707-436225447-2287060836
To: <4991589848>;tag=19F05A11-851
CSeq: 102 INVITE
Max-Forwards: 70
Content-Length:   193
v=0
o=- 1345528914 1345528914 IN IP4 10.0.99.111
s=-
t=0 0
m=image 26272 udptl t38
a=T38FaxRateManagement:transferredTCF
a=T38FaxUdpEC:t38UDPRedundancy
a=sendrecv
*Mar  7 02:47:12.902: //2300/000000000000/SIP/Info/sipSPICheckFromToRequest: Found matching CB 83A87C30
*Mar  7 02:47:12.902: //2300/000000000000/SIP/Info/ccsip_new_msg_preprocessor: ****Found CCB in UAC table
*Mar  7 02:47:12.902: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.100,Port 5060, Transport 1, SentBy Port 5060
*Mar  7 02:47:12.902: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar  7 02:47:12.906: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.100,Port 5060, Transport 1, SentBy Port 5060
*Mar  7 02:47:12.906: //2300/000000000000/SIP/Info/sact_active_new_message_request: Case of Mid-Call INVITE/UPDATE in ACTIVE STATE
*Mar  7 02:47:12.910: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetGtdBody: No valid GTD body found.
*Mar  7 02:47:12.910: //2300/000000000000/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
*Mar  7 02:47:12.910: //2300/000000000000/SIP/Info/sipSPIDoFaxMediaNegotiation: T.38 negotiated
*Mar  7 02:47:12.910: //2300/000000000000/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=26272 new=26272
*Mar  7 02:47:12.914: //2300/000000000000/SIP/Media/sipSPIGetNewLocalMediaDirection:
        retVal = 0
*Mar  7 02:47:12.914: //2300/000000000000/SIP/Media/sipSPICompareMediaType: Media type switching from 0 to 11 for stream 1
*Mar  7 02:47:12.914: //2300/000000000000/SIP/Media/sipSPICompareStreams: negotiated codec changed from g711alaw to T38Fax
*Mar  7 02:47:12.914: //2300/000000000000/SIP/Media/sipSPICompareStreams: negotiated dtmf relay changed from rtp-nte to inband-voice
*Mar  7 02:47:12.914: //2300/000000000000/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=Yes CAPS_CHANGE=Yes
*Mar  7 02:47:12.914: //2300/000000000000/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=Yes DSPDNLD_REQD=Yes IPIP_MEDIA=Yes
*Mar  7 02:47:12.914: //2300/000000000000/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : Yes
        New Media              : Yes
        DSP DNLD Reqd          : Yes
*Mar  7 02:47:12.918: //2300/000000000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Mar  7 02:47:12.918: //2300/000000000000/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 2300 peer 2299 flags 0x4D0F
*Mar  7 02:47:12.918: //2300/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 2300, sdp 0x83BC49B4 channels 0x83A897E0
*Mar  7 02:47:12.918: //2300/000000000000/SIP/Info/copy_channels:
callId 2300 size 80 ptr 0x83BC6340)
Finished storing fax attrs 1 type 1 prot 0, rmgmt 1 maxbuff 0 max dgram 0
SIP: Attribute ptime, level 1 instance 1 not found.
Call 2300 setting xmit func to udp
*Mar  7 02:47:12.918: //2299/AAFC2366ACD4/SIP/Info/ccsip_remote_codec_download_done:
callId 2299 context 0x82BD22E0
Call 2300 set InfoType to FAX
*Mar  7 02:47:12.922: //2300/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
*Mar  7 02:47:12.922: //-1/xxxxxxxxxxxx/SIP/Error/convert_codec_bytes_to_ptime: Unexpected VoIPCodec Type :T38Fax
*Mar  7 02:47:12.922: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: T38Fax codecbytes :20, ptime: 0
*Mar  7 02:47:12.922: //2300/000000000000/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=0,stream->negotiated_codec_bytes=20, coverted ptime=0 stream->mline_index=1, media_ndx=1
Adding codec 17 ptype 0 time 0, bytes 20  as channel 0 mline 1 ss 0 10.0.99.111:26272
*Mar  7 02:47:12.922: //2300/000000000000/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report reINVITE media
*Mar  7 02:47:12.922: //2300/000000000000/SIP/Info/copy_channels:
*Mar  7 02:47:12.926: //2299/AAFC2366ACD4/SIP/Info/ccsip_modify_media_ind: codec=0x10000 modem_redundancy=2207967832 callID 2299 peer callID 2300
*Mar  7 02:47:12.926: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_MEDIA_CHANGED
*Mar  7 02:47:12.926: //2300/000000000000/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Media line             : 1
          State                  : STREAM_CHANGING (4)
          Callid                 : -1
          Negotiated Codec       : T38Fax, bytes :20
*Mar  7 02:47:12.926: //2300/000000000000/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
*Mar  7 02:47:12.926: //2300/000000000000/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
*Mar  7 02:47:12.926: //2300/000000000000/SIP/Media/sipSPIDeleteStream: Deleting stream 1 from the VOIP RTP library
*Mar  7 02:47:12.926: //2300/000000000000/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 2300) to the VOIP RTP library
*Mar  7 02:47:12.930: //2300/000000000000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.0.99.29
*Mar  7 02:47:12.930: //2300/000000000000/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Mar  7 02:47:12.930: //2300/000000000000/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
        laddr = 10.0.99.29, lport = 19298, raddr = 10.0.99.111, rport=26272, do_rtcp=FALSE
*Mar  7 02:47:12.930: //2300/000000000000/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
*Mar  7 02:47:12.930: //2300/000000000000/SIP/Media/sipSPIGetNewLocalMediaDirection:
        retVal = 0
*Mar  7 02:47:12.930: //2300/000000000000/SIP/Info/sipSPIProcessMediaChanges: DSPDNLD Reqd is true. Call DoCapsInd
*Mar  7 02:47:12.930: //2300/000000000000/SIP/Info/sipSPIIncomingCallSDP: SDP already there use old SDP and update media if needed
*Mar  7 02:47:12.934: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
*Mar  7 02:47:12.934: //2300/000000000000/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 19298
*Mar  7 02:47:12.934: //2300/000000000000/SIP/Info/sipSPI_ipip_build_t38_sdp:
*Mar  7 02:47:12.934: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
*Mar  7 02:47:12.934: //2300/000000000000/SIP/State/sipSPIChangeState: 0x83A87C30 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)
*Mar  7 02:47:12.934: //2300/000000000000/SIP/Info/sipSPIHandleIncomingMidCallInvite: ccsip_api_request_offer returned: SIP_SUCCESS
*Mar  7 02:47:12.938: //2300/000000000000/SIP/Event/sipSPICreateRpid: Received Octet3A=0x80 -> Setting ;screen=no ;privacy=off
*Mar  7 02:47:12.938: //2300/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x83C238E0, addr=10.0.99.100, port=5060, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x00000000
*Mar  7 02:47:12.938: //2300/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:12.938: //2300/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:12.938: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C238E0, addr=10.0.99.100, port=5060, connId=0 for UDP
*Mar  7 02:47:12.942: //2300/000000000000/SIP/Info/sipSPIProcessContactInfo: Previous Hop 10.0.99.100:5060
*Mar  7 02:47:12.942: //2299/AAFC2366ACD4/SIP/Info/act_active_media_changed: New codec = 17
*Mar  7 02:47:12.942: //2299/AAFC2366ACD4/SIP/Transport/sipSPISendErrorResponse: Sending ERROR Response to the transport layer
*Mar  7 02:47:12.946: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: msg=0x83C245D0, addr=10.0.99.121, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Mar  7 02:47:12.946: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:12.946: //2299/AAFC2366ACD4/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:12.946: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C245D0, addr=10.0.99.121, port=5061, connId=0 for UDP
*Mar  7 02:47:12.946: //2300/000000000000/SIP/Info/act_handle_app_media_event: Received media sip event SIP_RESPONSE_ANSWER
*Mar  7 02:47:12.950: //2300/000000000000/SIP/Event/sipSPICreateRpid: Received Octet3A=0x80 -> Setting ;screen=
Router#no ;privacy=off
*Mar  7 02:47:12.954: //2300/000000000000/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Mar  7 02:47:12.954: //2300/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x83C23CD0, addr=10.0.99.100, port=5060, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x80AAF2E0
*Mar  7 02:47:12.954: //2300/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:12.954: //2300/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:12.954: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C23CD0, addr=10.0.99.100, port=5060, connId=0 for UDP
*Mar  7 02:47:12.954: //2300/000000000000/SIP/Info/sentResponseStartConnectTimer: Sent Response, start ConnectTimer
*Mar  7 02:47:12.954: //2300/000000000000/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 10.0.99.111, RTCP Type 3
*Mar  7 02:47:12.954: //2300/000000000000/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
*Mar  7 02:47:12.958: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.0.99.100:5060;rport;branch=z9hG4bK-1580058559-3776009707-436225447-22870608361,SIP/2.0/UDP 10.0.99.111:5061;rport=5061;branch=z9hG4bK-1580058559-3776009707-436225447-2287060836;received=10.0.99.111
Date: Thu, 07 Mar 2002 02:47:12 GMT
CSeq: 102 INVITE
Remote-Party-ID: <4991589848>;party=called;screen=no;privacy=off
Content-Length: 0
*Mar  7 02:47:12.962: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 488 Not Acceptable Media
Warning: 304 10.0.99.29 "Media Type(s) Unavailable"
CSeq: 1 INVITE
Content-Length: 0
*Mar  7 02:47:12.966: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Contact: <4991589848>
Content-Length: 151
v=0
o=CiscoSystemsSIP-GW-UserAgent 5758 6867 IN IP4 10.0.99.29
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
m=image 19298 udptl t38
c=IN IP4 10.0.99.29
*Mar  7 02:47:12.970: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.121:5061
*Mar  7 02:47:12.974: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.100:5060
*Mar  7 02:47:12.974: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:12.978: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  7 02:47:12.978: //2299/AAFC2366ACD4/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x83A98764
*Mar  7 02:47:12.982: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5060
*Mar  7 02:47:12.982: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar  7 02:47:12.982: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5061
*Mar  7 02:47:12.986: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:12.986: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:4991589848@10.0.99.29:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.99.100:5060;rport;branch=z9hG4bK-3999912639-3776009707-436225447-22870608361
Via: SIP/2.0/UDP 10.0.99.111:5061;rport=5061;branch=z9hG4bK-3999912639-3776009707-436225447-2287060836;received=10.0.99.111
CSeq: 102 ACK
Contact: <4957887603>
Max-Forwards: 70
Content-Length: 0
*Mar  7 02:47:12.990: //2300/000000000000/SIP/Info/sipSPICheckFromToRequest: Found matching CB 83A87C30
*Mar  7 02:47:12.990: //2300/000000000000/SIP/Info/ccsip_new_msg_preprocessor: ****Found CCB in UAC table
*Mar  7 02:47:12.990: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.100,Port 5060, Transport 1, SentBy Port 5060
*Mar  7 02:47:12.990: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar  7 02:47:12.994: //2300/000000000000/SIP/Info/sipSPIProcessIncomingAckForMidCall: Processing MidCall ACK
*Mar  7 02:47:12.994: //2300/000000000000/SIP/State/sipSPIChangeState: 0x83A87C30 : State change from (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
*Mar  7 02:47:12.994: //2300/000000000000/SIP/Info/sipSPICreateAndStartRtpTimer:
*Mar  7 02:47:12.994: //2300/000000000000/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
*Mar  7 02:47:13.446: //2299/AAFC2366ACD4/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Mar  7 02:47:13.450: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: msg=0x83C238E0, addr=10.0.99.121, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Mar  7 02:47:13.450: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:13.450: //2299/AAFC2366ACD4/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:13.450: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C238E0, addr=10.0.99.121, port=5061, connId=0 for UDP
*Mar  7 02:47:13.454: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.0.99.121:5061;rport;branch=z9hG4bK-1962345899-3776009707-436262060-3629041508
From: <4991589848>;tag=46400939-3776009707-436262060-3629041508
Call-ID: ab05c434eb5511e1acd4001a64c74ed8@10.0.99.121
CSeq: 1 INVITE
Supported: replaces
Contact: <0001124957887603>
Content-Length: 256
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  7 02:47:13.459: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.121:5061
*Mar  7 02:47:13.459: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:13.459: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  7 02:47:13.463: //2299/AAFC2366ACD4/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x83A98764
*Mar  7 02:47:13.467: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5060
*Mar  7 02:47:13.467: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar  7 02:47:13.467: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5061
*Mar  7 02:47:14.452: //2299/AAFC2366ACD4/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Mar  7 02:47:14.452: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: msg=0x83C245D0, addr=10.0.99.121, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Mar  7 02:47:14.452: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:14.452: //2299/AAFC2366ACD4/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:14.452: //-1/xxxxxxxx
Router#xxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C245D0, addr=10.0.99.121, port=5061, connId=0 for UDP
*Mar  7 02:47:14.456: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 07 Mar 2002 02:47:13 GMT
CSeq: 1 INVITE
Supported: replaces
Content-Length: 256
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  7 02:47:14.460: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.121:5061
*Mar  7 02:47:14.460: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:14.460: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Mar  7 02:47:14.464: //2299/AAFC2366ACD4/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x83A98764
*Mar  7 02:47:14.468: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5060
*Mar  7 02:47:14.468: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar  7 02:47:14.468: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5061
Router#
*Mar  7 02:47:16.455: //2299/AAFC2366ACD4/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Mar  7 02:47:16.455: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: msg=0x83C22530, addr=10.0.99.121, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Mar  7 02:47:16.455: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:16.455: //2299/AAFC2366ACD4/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:16.455: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C22530, addr=10.0.99.121, port=5061, connId=0 for UDP
*Mar  7 02:47:16.459: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 07 Mar 2002 02:47:14 GMT
CSeq: 1 INVITE
Supported: replaces
Content-Length: 256
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  7 02:47:16.463: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.121:5061
*Mar  7 02:47:16.463: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:16.467: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Router#
*Mar  7 02:47:16.467: //2299/AAFC2366ACD4/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x83A98764
*Mar  7 02:47:16.471: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5060
*Mar  7 02:47:16.471: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar  7 02:47:16.471: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5061
Router#
*Mar  7 02:47:20.458: //2299/AAFC2366ACD4/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Mar  7 02:47:20.458: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: msg=0x83C22BF0, addr=10.0.99.121, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Mar  7 02:47:20.458: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:20.458: //2299/AAFC2366ACD4/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:20.458: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C22BF0, addr=10.0.99.121, port=5061, connId=0 for UDP
*Mar  7 02:47:20.462: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 07 Mar 2002 02:47:16 GMT
CSeq: 1 INVITE
Supported: replaces
Content-Length: 256
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  7 02:47:20.466: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.121:5061
*Mar  7 02:47:20.466: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:20.470: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Router#
*Mar  7 02:47:20.470: //2299/AAFC2366ACD4/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x83A98764
*Mar  7 02:47:20.474: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5060
*Mar  7 02:47:20.474: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar  7 02:47:20.474: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5061
Router#
*Mar  7 02:47:24.457: //2299/AAFC2366ACD4/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Mar  7 02:47:24.461: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: msg=0x83C238E0, addr=10.0.99.121, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Mar  7 02:47:24.461: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:24.461: //2299/AAFC2366ACD4/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:24.461: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C238E0, addr=10.0.99.121, port=5061, connId=0 for UDP
*Mar  7 02:47:24.465: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 07 Mar 2002 02:47:20 GMT
CSeq: 1 INVITE
Supported: replaces
Content-Length: 256
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=fmtp:101 0-15
*Mar  7 02:47:24.469: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.121:5061
*Mar  7 02:47:24.469: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:24.473: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Router#
*Mar  7 02:47:24.473: //2299/AAFC2366ACD4/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x83A98764
*Mar  7 02:47:24.477: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5060
*Mar  7 02:47:24.477: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar  7 02:47:24.477: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5061
Router#
*Mar  7 02:47:26.760: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.100:5060
*Mar  7 02:47:26.764: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:26.764: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:4959848932@10.0.99.29:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.99.100:5060;rport;branch=z9hG4bK-1627196104-3776009707-436225447-22870608361
Via: SIP/2.0/UDP 10.0.99.111:5061;rport=5061;branch=z9hG4bK-1627196104-3776009707-436225447-2287060836;received=10.0.99.111
From: <4957873222>;tag=76313999-3776009707-436225447-2287060836
To: <4959848932>;tag=19EF4E54-E78
Call-ID: 45D3961B-30AC11D6-88FFED6C-C23DC168@10.0.99.29
CSeq: 102 BYE
Contact: <4957873222>
Max-Forwards: 70
Reason: MVTSLocal;cause=10;text="BYE received"
Content-Length: 0
*Mar  7 02:47:26.768: //2296/000000000000/SIP/Info/sipSPICheckFromToRequest: Found matching CB 83A809AC
*Mar  7 02:47:26.768: //2296/000000000000/SIP/Info/ccsip_new_msg_preprocessor: ****Found CCB in UAC table
*Mar  7 02:47:26.768: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.100,Port 5060, Transport 1, SentBy Port 5060
*Mar  7 02:47:26.768: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar  7 02:47:26.772: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.100,Port 5060, Transport 1, SentBy Port 5060
*Mar  7 02:47:26.772: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[2296], src[4]
*Mar  7 02:47:26.772: //2296/000000000000/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
*Mar  7 02:47:26.772: //2296/000000000000/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(16) for outgoing call
*Mar  7 02:47:26.772: //2296/000000000000/SIP/State/sipSPIChangeState: 0x83A809AC : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Mar  7 02:47:26.776: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
*Mar  7 02:47:26.780: //2295/82291160ACD4/SIP/Info/sipSPIValidateGtd: No rawMsg from CCAPI
*Mar  7 02:47:26.780: //2295/82291160ACD4/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
*Mar  7 02:47:26.780: //2295/82291160ACD4/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
*Mar  7 02:47:26.784: //2295/82291160ACD4/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Mar  7 02:47:26.784: //2295/82291160ACD4/SIP/Transport/sipSPITransportSendMessage: msg=0x83C22530, addr=10.0.99.121, port=5061, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x80AAEE84
*Mar  7 02:47:26.784: //2295/82291160ACD4/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:26.784: //2295/82291160ACD4/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:26.784: //2295/82291160ACD4/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x83C22530
*Mar  7 02:47:26.784: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C22530, addr=10.0.99.121, port=5061, connId=3 for UDP
*Mar  7 02:47:26.784: //2295/82291160ACD4/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
*Mar  7 02:47:26.784: //2295/82291160ACD4/SIP/State/sipSPIChangeState: 0x83A9D3BC : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Mar  7 02:47:26.788: //2296/000000000000/SIP/Transport/sipSPISendByeResponse: Sending BYE Response to the transport layer
*Mar  7 02:47:26.788: //2296/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x83C245D0, addr=10.0.99.100, port=5060, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x80AAF150
*Mar  7 02:47:26.788: //2296/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:26.788: //2296/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:26.788: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C245D0, addr=10.0.99.100, port=5060, connId=0 for UDP
*Mar  7 02:47:26.792: //2296/000000000000/SIP/Info/sentByeResponse: Sent 200ok to the BYE, tearing down the call
*Mar  7 02:47:26.792: //2296/000000000000/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:43520854 ConnTime 43511402
*Mar  7 02:47:26.796: //2296/000000000000/SIP/State/sipSPIChangeState: 0x83A809AC : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
*Mar  7 02:47:26.796: //2296/000000000000/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x83A809AC
State of The Call        : STATE_DEAD
Calling Number           : 4959848932
Called Number            : 4957873222
*Mar  7 02:47:26.796: //2296/000000000000/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec         : g711alaw
Source IP Port    (Media): 16754
Destn  IP Port    (Media): 26228
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
*Mar  7 02:47:26.796: //2296/000000000000/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 8F8
*Mar  7 02:47:26.800: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:4959848932@10.0.99.121:5061;user=phone SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bKB0E679
To: <4959848932>;tag=236596354-3776009707-436262060-3629041508
Date: Thu, 07 Mar 2002 02:45:52 GMT
Call-ID: 822c1a36eb5511e1acd4001a64c74ed8@10.0.99.121
Max-Forwards: 70
Timestamp: 1015469246
CSeq: 101 BYE
Content-Length: 0
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.0.99.100:5060;rport;branch=z9hG4bK-1627196104-3776009707-436225447-22870608361,SIP/2.0/UDP 10.0.99.111:5061;rport=5061;branch=z9hG4bK-1627196104-3776009707-436225447-2287060836;received=10.0.99.111
Date: Thu, 07 Mar 2002 02:47:26 GMT
Content-Length: 0
CSeq: 102 BYE
*Mar  7 02:47:26.808: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.121:5061
*Mar  7 02:47:26.808: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:26.812: //2295/82291160ACD4/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x83A9D3BC
*Mar  7 02:47:26.812: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Contact: <4959848932>
Content-Length: 0
*Mar  7 02:47:26.812: //2295/82291160ACD4/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:43520856 ConnTime 43511406
*Mar  7 02:47:26.816: //2295/82291160ACD4/SIP/State/sipSPIChangeState: 0x83A9D3BC : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
*Mar  7 02:47:26.816: //2295/82291160ACD4/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x83A9D3BC
Called Number            : 0001124957873222
*Mar  7 02:47:26.816: //2295/82291160ACD4/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 18464
Destn  IP Port    (Media): 32422
*Mar  7 02:47:26.820: //2295/82291160ACD4/SIP/Call/sipSPICallInfo:
*Mar  7 02:47:26.820: //2295/82291160ACD4/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 8F7
*Mar  7 02:47:26.820: //2295/82291160ACD4/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
*Mar  7 02:47:26.820: //2295/82291160ACD4/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x83A9D3BC key=822c1a36eb5511e1acd4001a64c74ed8@10.0.99.1210001124957873222
*Mar  7 02:47:26.820: //2295/82291160ACD4/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
*Mar  7 02:47:26.820: //2295/82291160ACD4/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x83A9D3BC key=822c1a36eb5511e1acd4001a64c74ed8@10.0.99.12119EF4E04-2605
Router#
*Mar  7 02:47:26.824: //2295/82291160ACD4/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Mar  7 02:47:26.824: //2295/82291160ACD4/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 83A9D3BC
Router#
*Mar  7 02:47:28.459: //2299/AAFC2366ACD4/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
*Mar  7 02:47:28.463: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: msg=0x83C232B0, addr=10.0.99.121, port=5061, sentBy_port=5061, is_req=0, transport=1, switch=0, callBack=0x00000000
*Mar  7 02:47:28.463: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:28.463: //2299/AAFC2366ACD4/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:28.463: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C232B0, addr=10.0.99.121, port=5061, connId=0 for UDP
*Mar  7 02:47:28.467: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <0001124957887603>;tag=19F059BD-1F7C
Date: Thu, 07 Mar 2002 02:47:24 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
Supported: replaces
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Length: 256
v=0
s=SIP Call
c=IN IP4 10.0.99.29
t=0 0
c=IN IP4 10.0.99.29
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
*Mar  7 02:47:28.471: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.121:5061
*Mar  7 02:47:28.471: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:28.471: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Router#
*Mar  7 02:47:28.475: //2299/AAFC2366ACD4/SIP/Info/sipSPIFindCcbUASReqTable: *****CCB found in UAS Request table. ccb=0x83A98764
*Mar  7 02:47:28.479: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5060
*Mar  7 02:47:28.479: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar  7 02:47:28.479: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 10.0.99.121,Port 5061, Transport 1, SentBy Port 5061
Router#
*Mar  7 02:47:31.424: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x83C22410,addr=10.0.99.99
*Mar  7 02:47:32.462: //2299/AAFC2366ACD4/SIP/Error/act_active_wait_ack: Out of retries
*Mar  7 02:47:32.462: //2299/AAFC2366ACD4/SIP/Info/ccsip_set_cc_cause_for_spi_err: Categorized cause:102, category:129
*Mar  7 02:47:32.462: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[2299], src[6]
*Mar  7 02:47:32.462: //2299/AAFC2366ACD4/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(127) for incoming call
*Mar  7 02:47:32.462: //2299/AAFC2366ACD4/SIP/State/sipSPIChangeState: 0x83A98764 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Mar  7 02:47:32.462: //2299/AAFC2366ACD4/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
*Mar  7 02:47:32.466: //2299/AAFC2366ACD4/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
*Mar  7 02:47:32.466: //2299/AAFC2366ACD4/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Mar  7 02:47:32.466: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: msg=0x83C22A40, addr=10.0.99.121, port=5061, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x80AAEE84
*Mar  7 02:47:32.466: //2299/AAFC2366ACD4/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:32.466: //2299/AAFC2366ACD4/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:32.466: //2299/AAFC2366ACD4/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x83C22A40
*Mar  7 02:47:32.470: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C22A40, addr=10.0.99.121, port=5061, connId=3 for UDP
*Mar  7 02:47:32.470: //2299/AAFC2366ACD4/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
*Mar  7 02:47:32.470: //2299/AAFC2366ACD4/SIP/State/sipSPIChangeState: 0x83A98764 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Mar  7 02:47:32.474: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:4991589848@10.0.99.121:5061;user=phone SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bKB0F5D4
To: <4991589848>;tag=46400939-3776009707-436262060-3629041508
Date: Thu, 07 Mar 2002 02:47:28 GMT
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1015469252
CSeq: 101 BYE
Content-Length: 0
*Mar  7 02:47:32.478: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.121:5061
*Mar  7 02:47:32.478: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:32.478: //2299/AAFC2366ACD4/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x83A98764
*Mar  7 02:47:32.478: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Server: MERA MVTS3G v.4.4.0-15
Content-Length: 0
*Mar  7 02:47:32.482: //2299/AAFC2366ACD4/SIP/Info/sipSPIIcpifUpdate: CallState: 3 Playout: 0 DiscTime:43521422 ConnTime 43518950
*Mar  7 02:47:32.486: //2299/AAFC2366ACD4/SIP/State/sipSPIChangeState: 0x83A98764 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
*Mar  7 02:47:32.486: //2299/AAFC2366ACD4/SIP/Call/sipSPICallInfo:
*Mar  7 02:47:32.486: //2299/AAFC2366ACD4/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Disconnect Cause (CC)    : 127
*Mar  7 02:47:32.486: //2299/AAFC2366ACD4/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 8FB
*Mar  7 02:47:32.486: //2299/AAFC2366ACD4/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
*Mar  7 02:47:32.490: //2299/AAFC2366ACD4/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x83A98764 key=ab05c434eb5511e1acd4001a64c74ed8@10.0.99.1210001124957887603
*Mar  7 02:47:32.490: //2299/AAFC2366ACD4/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
*Mar  7 02:47:32.490: //2299/AAFC2366ACD4/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x83A98764 key=ab05c434eb5511e1acd4001a64c74ed8@10.0.99.12119F059BD-1F7C
*Mar  7 02:47:32.490: //2299/AAFC2366ACD4/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Mar  7 02:47:32.494: //2299/AAFC2366ACD4/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 83A98764
*Mar  7 02:47:32.498: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
*Mar  7 02:47:32.498: //2300/000000000000/SIP/Info/sipSPIValidateGtd: No rawMsg from CCAPI
*Mar  7 02:47:32.498: //2300/000000000000/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
*Mar  7 02:47:32.502: //2300/000000000000/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
*Mar  7 02:47:32.502: //2300/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
*Mar  7 02:47:32.502: //2300/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x83C22920, addr=10.0.99.100, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x80AAEE84
*Mar  7 02:47:32.502: //2300/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  7 02:47:32.502: //2300/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  7 02:47:32.502: //2300/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x83C22920
*Mar  7 02:47:32.502: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x83C22920, addr=10.0.99.100, port=5060, connId=1 for UDP
*Mar  7 02:47:32.506: //2300/000000000000/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
*Mar  7 02:47:32.506: //2300/000000000000/SIP/State/sipSPIChangeState: 0x83A87C30 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Mar  7 02:47:32.506: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:4957887603@10.0.99.100:5060 SIP/2.0
Via: SIP/2.0/UDP  10.0.99.29:5060;branch=z9hG4bKB1017F4
To: <4957887603>;tag=343429304-3776009707-436225447-2287060836
Call-ID: 6EAE04D4-30AC11D6-8903ED6C-C23DC168@10.0.99.29
Max-Forwards: 70
CSeq: 102 BYE
Content-Length: 0
*Mar  7 02:47:32.510: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.0.99.100:5060
*Mar  7 02:47:32.514: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Mar  7 02:47:32.514: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
*Mar  7 02:47:32.514: //2300/000000000000/SIP/Info/sipSPIIcpifUpdate: CallState: 3 Playout: 0 DiscTime:43521426 ConnTime 43518947
*Mar  7 02:47:32.518: //2300/000000000000/SIP/State/sipSPIChangeState: 0x83A87C30 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
*Mar  7 02:47:32.518: //2300/000000000000/SIP/Call/sipSPICallInfo:
*Mar  7 02:47:32.518: //2300/000000000000/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec Bytes   : 20
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0
*Mar  7 02:47:32.522: //2300/000000000000/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 8FC
Router#
*Mar  7 02:47:32.522: //2300/000000000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
*Mar  7 02:47:32.522: //2300/000000000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x83A87C30 key=6EAE04D4-30AC11D6-8903ED6C-C23DC168@10.0.99.29
*Mar  7 02:47:32.522: //2300/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
*Mar  7 02:47:32.522: //2300/AAFC2366ACD4/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 83A87C30
Router#
...and...
Router# sh run
Building configuration...
Current configuration : 3224 bytes
version 12.4
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$0bQK$KdOtiq2t/yndckQ/E33Y./
no aaa new-model
ip cef
ip name-server 10.0.99.101
voice service voip
allow-connections sip to sip
voice class uri  Centrex sip
host ^10\.0\.99\.111$
voice class uri  RTU1 sip
host ^10\.0\.99\.121$
voice class uri  RTU2 sip
host ^10\.0\.99\.221$
voice class codec 1
codec preference 1 g711alaw bytes 80
codec preference 2 clear-channel
voice translation-rule 112
rule 1 /^000112\(.*\)$/ /\1/
voice translation-rule 999
rule 1 /^999\(.*\)$/ /000\1/
voice translation-rule 999112
rule 1 /^\(.*\)$/ /999112\1/
voice translation-profile 112
translate called 112
voice translation-profile 999
translate called 999
voice translation-profile 999112
translate called 999112
username eyatsko privilege 15 password 7 123F0D01141E180826213D7B
username vshestopalov password 7 15241804557C7A75796A6271
interface FastEthernet0/0
no ip address
speed auto
interface FastEthernet0/0.18
encapsulation dot1Q 18
ip address 10.0.99.29 255.255.255.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.0.99.1
no ip http server
no ip http secure-server
snmp-server community public RO
snmp-server location msk
snmp-server contact eyatsko@ngs.ru
control-plane
dial-peer voice 999112 voip
translation-profile incoming 999112
voice-class codec 1
session protocol sipv2
incoming uri from Centrex
dtmf-relay rtp-nte
fax-relay ecm disable
fax rate 9600
fax nsf 000000
fax protocol t38 ls-redundancy 3 hs-redundancy 0 fallback pass-through g711alaw
no vad
dial-peer voice 999 voip
translation-profile outgoing 999
destination-pattern 999.+
voice-class codec 1
session target ipv4:10.0.99.99
session transport udp
dtmf-relay rtp-nte
fax rate 9600
fax nsf 000000
no vad
dial-peer voice 112 voip
translation-profile outgoing 112
destination-pattern 000112.+
voice-class codec 1
session target ipv4:10.0.99.100
dtmf-relay rtp-nte
fax rate 9600
fax nsf 000000
no vad
dial-peer voice 901 voip
voice-class codec 1
incoming uri from RTU1
dtmf-relay rtp-nte
fax rate 9600
fax nsf 000000
no vad
dial-peer voice 902 voip
voice-class codec 1
incoming uri from RTU2
dtmf-relay rtp-nte
fax rate 9600
fax nsf 000000
no vad
line con 0
exec-timeout 1440 0
logging synchronous
login local
line aux 0
line vty 0 4
exec-timeout 1440 0
logging synchronous
login local
line vty 5 15
exec-timeout 1440 0
logging synchronous
login local
end
Router#
...and just in case:
Router# sh ver
Cisco IOS Software, C1700 Software (C1700-IPVOICEK9-M), Version 12.4(25d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 18-Aug-10 03:47 by prod_rel_team
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
Router uptime is 5 days, 59 minutes
System returned to ROM by reload
System image file is "flash:c1700-ipvoicek9-mz.124-25d.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1760 (MPC860P) processor (revision 0x851) with 89590K/8714K bytes of memory.
Processor board ID FOC0951580U (2749394119), with hardware revision 0000
MPC860P processor: part number 5, mask 2
1 FastEthernet interface
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Router#
Cisco 1760 SIP-to-SIP GW T.38 does not work!
I don't understand the exact reason that cause the issue.
The debug shows a right negotiation of T.38 but at the moment there is an error: *Mar  7 02:47:12.942: //2299/AAFC2366ACD4/SIP/Info/act_active_media_changed: New codec = 17
I've a doubt. Can you add these commands to the config?
voice call send-alert
voice rtp send-recv
sip-ua
disable-early-media 180
Let me know the result.
Regards.
Thank you Daniele for your assistance!
I have added these commands but result is the same:
   SIP Status: 488 Not Acceptable Media
:-( What's wrong with me?.. Or with my Cisco?.. :-) We bought it used especially for these purposes...
Kind regards,
Ellad
Are there some unused FAX-commands? Something tells me the matter in Fax settings...
Is anybody here? :-)
Kind regards,
Ellad
Is there somebody who can help me?
Kind regards,
Ellad
Problem was resolved by upgrading IOS on T(est)-version.
In mainstream version SIP-to-SIP switchover in T.38 mode doesn't work.
Special thanks and glory to JTR!
Kind regards,
Ellad
What was the final IOS version used to solve the issue.
3113
