Class-Default bandwidth question
Hi all,
Can someone point me to another source of documentation that confirms the actual bandwidth allocated to the Class-Default when no specific Bandwidth Percent command is given?
policy-map scheduler-lmc
class prec5
priority percent 10
class prec3
bandwidth percent 50
class class-default
fair-queue
Link Bandwidth: 4000
Link type: Ethernet
max-reserved-bandwidth is Default: 75%
Question: What percentage of link BW is allocated to the Class-Default?
My own argument would be:
75% (max-reserved-bandwidth) -/- 60 %(LLQ + 2nd Q) = 15%
I follow this reasoning because when I attempt to configure the Class-Default with the Bandwidth Percent command, I am only allowed to configure 15%.
HOWEVER: According to the infromation provided in the link below: Class-Default takes it?s bandwidth from the percentage that is not available for allocation to configured classes, read: 25% (100% of link BW -/- 75% max-reserved-bandwidth).
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt2/qcfconmg.htm#wp1003189
Re: Class-Default bandwidth question
Reinier,
Here is a blurb from the QoS SRND that backs up your previous document. Of course this is a blurb referencing configuration of max-reserved bandwidth on a PPP Multilink but it reiterates the behaviour of the class-default.
Basically what I get out of this is class-default is reserved the 25% of the link unless a specific bandwidth value is specified. If a specific bandwidth value is assigned then the max-reserved bandwidth needs to be adjusted as it will no longer use the 25% reserved and will be subject to whatever percentage you specifiy of the 75%. Most complex QoS designs I've done, I have used the max-bandwidth and specified my bandwidth for my different classe, as per the 11 class QoS Model.
QOS SRND Blurb
The Scavenger class constrains any traffic marked to DSCP CS1 to 1 percent of the link; this allows
class-default to use the remaining 25 percent. However, to constrain Scavenger to 1 percent, an explicit
bandwidth guarantee (of 25 percent) must be given to the Best-Effort class. Otherwise, if class-default
is not explicitly assigned a minimum bandwidth guarantee, the Scavenger class still can rob it of
bandwidth. This is because of the way the CBWFQ algorithm has been coded: If classes protected with
a bandwidth statement are offered more traffic than their minimum bandwidth guarantee, the algorithm
tries to protect such excess traffic at the direct expense of robbing bandwidth from class-default (if
class-default is configured with fair-queue), unless class-default itself has a bandwidth statement
(providing itself with a minimum bandwidth guarantee). However, assigning a bandwidth statement to
class-default (on nondistributed platforms) currently precludes the enabling of fair queuing (fair-queue)
on this class and forces FIFO queuing on class-default (this limitation is to be removed with the release
of Consistent QoS Behavior code).
An additional implication of using a bandwidth statement on class-default is that even though 25
percent of the link is reserved explicitly for class-default, the parser will not attach the policy to an
interface unless the max-reserved-bandwidth 100 command is entered on the interface before the service-policy output statement. This is because the parser adds the sum of the bandwidth statements
(regardless of whether one of these is applied to the class-default) and, if the total is in excess of 75
percent of the link?s bandwidth, rejects the application of the policy to the interface. This is shown in the
following code:
interface Multilink1
description T1 to Branch#60
ip address 10.1.112.1 255.255.255.252
max-reserved-bandwidth 100 ! overrides the default 75% BW limit
service-policy output WAN-EDGE ! attaches the MQC policy
ppp multilink
ppp multilink group 1
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/ccmigration_09186a008049b062.pdf
Please rate any helpful posts
Fred
Thanks for your insights Fred, this significantly clarifies things!
I am left to wonder however over part of the above text and accompanying configuration.
"The Scavenger class constrains any traffic marked to DSCP CS1 to 1 percent of the link; this allows
class-default to use the remaining 25 percent"
Do you think this could imply that, when NOT using the Bandwidth statement for Class-Default, we are required to completely reserve the max-reserved-bandwidth for other classes (through Bandwidth statements) in order for the Class-Default to be consigned to the remaining 25% (link bw - max-reserved-bandwidth)? In other words, if we do not configure the 1% scavenger class, will Class-Default end up with 1% instead of the 25%?
Any thoughts would be very much appreciated!:-)
Reiner,
The blurb I took from the SRND was at the beginning of the Five-Class QoS model section. Basically what I get out of it is there is a limitation on the QoS behavior across the platforms. Below is their main point.
So with that being said, if class-default is not explictly set with a bandwidth value, then any oversubscribed CBWFQ can rob bandwidth from the 25% default (assuming you have left the default max of 75%). Unfortunately when they speak of oversubscribtion on the CBWFQ, I'm unsure if they say the IOS can natively go above it's limit (say 1% for scav) or only if it's invoked by a command that allows for fluctating queue sizes, 'bandwidth remaining'. I believe at this point it can go over the limit of a CBWFQ, if there is unspecified class-default available. I think they would've mentioned the other command in the SRND if that was the way it was invoked.
Fred
2016
