CME / Call Blocking with COR-Lists
Hi!
I created an (outgoing) dial-peer with destination pattern 0900 incl. cor-list.
If no cor-list (incoming) is set to an incoming dial-peer (dn) used by an ephone -> the ephone can use any outgoing dial-peer, without any restrictions, right?
Is it possible to set any kind of global rule for sip/ephones/fxs ports to be sure, the outgoing cor at die outgoing dial-peer matches for every incoming dial-peer?
1 REPLY
Hall of Fame Super Gold
Re: CME / Call Blocking with COR-Lists
Hi peter,
When incoming DP has no COR, but outgoing has one, the call succeeds. Please see a table with all combinations:
http://cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
I do not quite understand your second question, but if you want an easy way to set or change COR for all the phones, you can use ephone-dn-template.
Hope this helps, please rate all useful posts using the scrollbox below!
180
