Combining 2E1 Controllers to act as 1 for voice calls
Dear All,
I have a VWIC2-2MFT-T1/E1 card which is connected to a Siemens PBX using 2 E1 controllers (using Q-SIG). I also have enough PVDM2 modules to accomodate 60 voice channels.
I want to utilize both controllers on this card to get 60 voice channels. However, i would like to group both of these controllers somehow, to act as one. Basically i just want to increase the number of voice calls between the PBX and the router, but the routing of calls to thats PBX should consider both cpontrollers as one logical interface. Is there a command that can allow me to do that, something like trunk-group or pri-group.
Appreciate your help.
Mouhannad El Hajj-Mahmoud
1 REPLY
Hall of Fame Super Gold
Re: Combining 2E1 Controllers to act as 1 for voice calls
Sure, trunk-groups
trunk group to-pbx
hunt-scheme least-used
interface x/y/0:15
trunk-group to-pbx
interface x/y/1:15
trunk-group to-pbx
dial-peer voice 100 pots
destination-pattern 3...
incoming called-number 4...
direct-inward-dial
trunkgroup to-pbx
Hope this helps, if so please rate post!
122
