Communication between two ATA 186
Hi, can i comunicate two ATA 186 directly ?
I want to talk directly between them.
How can i do it ?
Beste Regards..
Luis
Silver
Re: Communication between two ATA 186
ATA 186 is used to connect Analog phones to an IP network and cannot be conencted back to back. But you can do with a Gatekeeper setup. The below link has the details.
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_configuration_example09186a0080094669.shtml
Ok. I have a router 3600, with a upgrade can it be a Gatekeeper.
Hi, another doubt,
communication between several ATA´s, with a gatekeeper can i get it, or do i need another device more ?
thanks, best regards.
Hi. You can set ATA's back to back configuring the IP address of the remote ATA in the Gateway field. If you need to connect several ATA's then you'll need a GK.
Example:
Analog_Phone---ATA---(IP_NETWORK)---ATA---Analog_Phone
or
GK
|---ATA
|---ATA
|---ATA
|---ATA
Hi, i have configurated these with a gatekeeper,
do you know how can i change the voice codec ?
Voice codecs1
G.729, G.729A, G.729AB2
G.723.1
G.711a-law
G.711µ-law
159
