Compression is not visible within eg. "sh policy-map" ?
I have configured "rtp header-compression" but when I look at the "show policy-map" I do not see the reduced output traffic (bandwidth consumption). I always see the traffic volume before the compression which is not the reality on the physical link.
So I would need to make all class-definitions without regard to compression and also do not see how much bandwidth is really used by eg. the voice-class, right?
Is this right or is there any solution to see the real bandwidth consumption on the link.
Chris
Bronze
Re: Compression is not visible within eg. "sh policy-map" ?
The show interface command should give you a lot of details on the link usage.
You could watch the load, 5 minute input rate/output rate fields before compression and after compression to find
the realistic usage.
I am pasting a sample show interface output below
Router#sh int s0
Serial0 is up, line protocol is up
Hardware is HD64570
Internet address is 192.168.100.2/24
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, rely 255/255, load 1/255
Encapsulation HDLC, loopback not set, keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 13:32:47
Input queue: 1/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/2/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
5 minute input rate 3000 bits/sec, 4 packets/sec
5 minute output rate 2000 bits/sec, 4 packets/sec
98631 packets input, 8680095 bytes, 0 no buffer
Received 30857 broadcasts, 0 runts, 0 giants, 0 throttles
2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
98332 packets output, 8924943 bytes, 0 underruns
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
what I mean is that the compression is not reflected to QoS-commands and there calculations, right ??
Chris
150
