Community Member
Configuring ATA 186
We have a single 2610XM Router at central site and all remote 805 Routers.We want to configure ATA 186 at all the sites for VoIP connectivity.Can we configure the Gateway and Gatekeeper on the single 2610XM Router?It has come loaded with h.323 software feature set and has flash of 16MB and DRAM 32MB.
Pls suggest a solution.
Re: Configuring ATA 186
Yes you can run both Gatekeeper and Gateway functions on the 2610XM router at the same time. You may need to bump your DRAM up in order to run the latest images that support both Gatekeeper and Gateway functionality. For example you could use the following image (c2600-ix-mz.12.3-1a) which is the IP/H323 featureset in the 12.3 release train. The minimum memory requirement for this is 48Megs of DRAM.
Once you have your gatekeeper configured, you would then configure your ATA's to point to the gatekeeper, and all your remote ATA's will be able to locate and call each other. If your 2610XM is also utilized as the PSTN gateway, then your remote ATA's can call out to the PSTN via the same router.
