Conflict in called numbers Conflict in called numbers ..... ???????? ....
Dears,
my company provide DIDs in range 63xxxxxx but this exactly same number for Phillipines Fix 63 in my CDR there is a conflict between Phillipines Fix 63 and my DIDs 63xxxxxx i need to Distinguishes between them i have my AS5400 and PGW2200 ... how can i do that?
translation-rule 2
Rule 2 ^5555#9626 6
Rule 6 ^06 6
Rule 7 ^07 7
translation-rule 1
Rule 7 ^06 6
Rule 8 ^07 7
Rule 10 ^5555#9627 7
dial-peer voice 1 pots
destination-pattern .T
progress_ind progress enable 8
progress_ind connect enable 8
translate-outgoing called 1
port 7/2:D
dial-peer voice 100 pots
incoming called-number 630000..
direct-inward-dial
forward-digits all
dial-peer voice 200 voip
destination-pattern 630000..
progress_ind setup enable 3
session protocol sipv2
session target ipv4:55.55.55.31
codec g711ulaw
fax-relay ecm disable
fax rate 14400
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
any help please?
1 REPLY
Silver
Re: Conflict in called numbers Conflict in called numbers .....
If you have a Cisco IOS Software gateway, a translation rule can be created and applied to the outbound Voice over IP (VoIP) dial peer. The following is an example configuration:
translation-rule 1
rule 1 ^0760 7300
dial-peer voice 10 voip
Telephony Signaling Configuration Examples and TechNotes
http://www.cisco.com/en/US/tech/tk652/tk653/tech_configuration_examples_list.html
145
