connecting T1 from PBX to 2800 router running CME
I have T1 provided by the Telecom group to connect to Call Manager express,
Can i connect to a FXO card  or Wic T1 card
i have following hardware on the router
2 FastEthernet interfaces
1 Serial interface
2 Serial(sync/async) interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
2 Voice FXO interfaces
2 Voice FXS interfaces
1 cisco service engine(s)
Sri
1 ACCEPTED SOLUTION
Super Bronze
Re: connecting T1 from PBX to 2800 router running CME
Nope, you can connect a T1 to a T1. Not an FXO (a completely different technology) or a WIC (they don't support voice).
It has to be a voice T1 (i.e. for a 2800 series this would normally be a VWIC-1MFT-T1/E1 or VWIC2-1MFT-T1/E1 or the 2-port versions of these).
You also need DSPs - at least 24 channels, so a PVDM2-32 should cover the T1 and the four analog ports you have (unless you need more for transcoding, G729 calls, etc..).
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Aaron
i have UC520  with the following configuration
will it be possible to connect
Cisco UC520-8U-4FXO-K9 (MPC8358) processor (revision 0x202) with 249856K/12288K bytes of m
emory.
Processor board ID FHK133975NA
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
14 User Licenses
10 FastEthernet interfaces
2 terminal lines
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
128K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
REMoteCCME#sh ds
REMoteCCME#sh dspfarm
DSPFARM Configuration Information:
Admin State: DOWN, Oper Status: DOWN - Cause code: ADMIN_STATE_DOWN
Transcoding Sessions: 0(Avail: 0), Conferencing Sessions: 0 (Avail: 0)
Trans sessions for mixed-mode conf: 0 (Avail: 0), RTP Timeout: 600
Connection check interval 600 Codec G729 VAD: ENABLED
Sri
Super Bronze
I thought you had a 2800...???
As I understand it the UC series are fixed config, so no T1, no connection...
Aaron
Yes, i have both 2800 and UC520
Thanks for your help
The UC520-8U-4FXO-K9 does have a VIC slot, so you could add an MFT card.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps7293/product_data_sheet0900aecd8061fb06.html
Hope this helps.
Brandon
1044
