connection plar on voice T-1 channels?
can you do connection plar on t-1 voice channels.
we have a scenerio where we need to be able to pass calls from unique T-1 voice channels to unique extensions in a remote site.
thanks in advance
Silver
Re: connection plar on voice T-1 channels?
If you are configuring CAS, you can configure a separate ds0 group for each timeslot, which will in turn create a separate voice port for each time slot and you can plar the voice port to a differnt extension, so in effect each timeslot will be plarred to a separate extension.
Taimoor
thanks, that makes sense!
so it should look something like this?
Controller t1 1/0
ds0-group 0 timeslots 1 type fxo-loopstart
ds0-group 1 timeslots 2 type fxo-loopstart
ds0-group 2 timeslots 3 type fxo-loopstart
ds0-group 23 timeslots 24 type fxo-loopstart
voice-port 1/0:0
connection plar 100
voice-port 1/0:1
connection plar 101
dial-peer voice 100 pots
destination-pattern 100
port 1/0:0
dial-peer voice 101 pots
destination-pattern 101
port 1/0:1
159
