Connection PLAR on WS-X6624 module
How do you do this on the FXS port. Similiar method on IOS is connection PLAR at the voice-port. How do you do it with CAT OS?
1 REPLY
Re: Connection PLAR on WS-X6624 module
Hi -
There is no PLAR specific config as far as the CatOS is concerned (assuming your 6624 is properly registered with CM).
Here is how you do it with CM:
1) Create a new partition for the PLAR (i.e. Loading Dock PLAR PRT)
2)Create a new search space for the PLAR (i.e. Loading Dock PLAR SS)
3)Add only the PLAR PRT to the new search space
4)Create a translation pattern using NO digits in the translation pattern field. Put it in the PLAR PRT and give it the appropriate search space. In the called party transformation mask field put in the phone number you want the PLAR to ring to.
5)Create an extension on the 6624 that has uses the new PLAR search space
6)done!
-Jaret
142
