04-12-2008 08:06 AM
I have a connection trunk quality problem between a 3640 and 3662 (or 3745) routers. After setting up the connection trunk, I tested the quality by sending a 1KHz tone (using an analog tester). Here is the result: -
Transmit........Receive.........Result
3640(NM-2V).....3662(NM-2V).....Tone receive good
3640(NM-2V).....3745(NM-HD-2V)..Tone receive good
3662(NM-2V).....3640(NM-2V).....Tone receive with noise
3745(NM-HD-2V)..3640(NM-2V).....Tone receive with noise
This problem doesn't happens if the connection trunk is between a 3662 and 3745 routers as the result below indicates.
3662(NM-2V).....3745(NM-HD-2V)..Tone receive good
3662(NM-2V).....3745(NM-2V).....Tone receive good
3745(NM-HD-2V)..3662(NM-2V).....Tone receive good
3745(NM-2V).....3662(NM-2V).....Tone receive good
Can someone tell me how can I solve this problem?
Here's what I have configured inside the routers: -
On the 3640 (with NM-2V and VIC-2E/M) -
interface Ethernet0/0
ip address 10.81.1.2 255.255.0.0
full-duplex
voice-port 1/0/0
echo-cancel coverage 32
no comfort-noise
timeouts wait-release 3
connection trunk 9001
operation 4-wire
type 2
signal immediate
dial-peer voice 9000 voip
destination-pattern 900.
session target ipv4:10.81.1.1
dtmf-relay h245-alphanumeric
codec g726r24
ip precedence 5
dial-peer voice 8001 pots
destination-pattern 8001
port 1/0/0
On the 3660 (with NM-2V and VIC-2E/M)
interface Ethernet6/1
ip address 10.81.1.1 255.255.0.0
full-duplex
voice-port 5/0/0
operation 4-wire
type 5
signal immediate
input gain 2
echo-cancel suppressor 9
timeouts call-disconnect 3
connection trunk 8001
dial-peer voice 9001 pots
destination-pattern 9001
port 5/0/0
dial-peer voice 8000 voip
destination-pattern 800.
session target ipv4:10.81.1.2
codec g726r24
ip qos dscp cs5 media
no vad
Thanks very much.
04-12-2008 10:10 AM
Does it happens with any codec, or g726 only? Which exact IOS are you using on the 3640 ?
04-13-2008 08:46 PM
It seems ok with codec g711ulaw. The analog tester tone is received without noise.
But I prefer to use g726r24 since the bandwidth utilization is much lower than the g711ulaw.
I'm running using c3640-is-mz.122-10d.bin on the 3640.
04-15-2008 04:46 AM
Upgrade 3640 to latest maintenance of 12.2 and try again. You can try g729 that is the best compromise and more tested codec.
