Controller Card
Dear All,
We have the attached configuration in our cisco 7206 router to facilitate voice calls. VXC-2TE1+ port has been inserted in Slot 1.
Now from one port s1/0 the outgoing calls are not going out but incoming calls are coming through with out any issue. As per the telecom technicians advice we need to change the card in slot 1. we are already procured a temp card for testing.
Now can i just insert the same card just like that ? after insertion do i need to configure everything which was there with the old card or it will be taken from the old card?
Once the testing is over i need to revert back the old card.kindly guide me to test the new card and revert back the old card after testing .
What are the neccessary steps i should follow to carry out the task.
Any response will be highly appreciated.
Shibu
1 REPLY
Hall of Fame Super Gold
Re: Controller Card
Already replied in duplicate thread.
167
