03-04-2004 11:44 AM
Attached is my Sh controller t1 1/0
hardware: VWIC-1mft-1t in a 2621xm
Circuit T1 CAS
My config works in the lab with a neax2000 PBX but when on site it will not come up. I have replaced all cables and test and replaced the hardware on the PBX. I am currentenly doing a RMA on the routers card. When I do a no shut I get the following error:Mar 3 18:01:41.313 EST: %CONTROLLER-5-UPDOWN: Controller T1 1/0, changed state to up Mar 3 18:02:09.284 EST: %CONTROLLER-5-UPDOWN: Controller T1 1/0, changed state to down (LOS detected)
Any help in case it is not the card.
T1 1/0 is down.
Applique type is Channelized T1
Cablelength is short 133
Description: Uplink to Neax 2000
Transmitter is sending remote alarm.
Receiver has loss of signal.
alarm-trigger is not set
Version info Firmware: 20020812, FPGA: 11
Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
Data in current interval (780 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 780 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 780 Unavail Secs
Total Data (last 24 hours)
2 Line Code Violations, 2294 Path Code Violations,
0 Slip Secs, 86368 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86371 Unavail Secs
Solved! Go to Solution.
03-09-2004 03:26 AM
this might have something to do with the problem:
First thing - check the cable.
If you want to proove the voice card, use a T1 loop back. On the Rj45, loop pins 1 to 4 and 2 to 5. If the port comes up, then the problem is external.
You may need a T1 cross over cable to connect the external equipment to the voice card. Here are the pinouts :
1-------4
2-------5
4-------1
5-------2
03-05-2004 11:45 PM
The simple test to see what devic is at fault is to test each controller with a hardware loopback plug. When the loopback is plugged into the controller, the T1 interface should come up. If it fails to come up, then you may have bad hardware, but this is rather unlikely. A method to make your own loopback plug is to connect pin 1 to 4 and pin 2 to 5 on a RJ45 connector.
Below is a that offers a method for using a hardware loopback to test a controller.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a7599.shtml
For your reference, below is a troubleshooting flow chart for T1 controllers that should be helpful
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a5f40.shtml
03-09-2004 03:26 AM
1-------4
2-------5
4-------1
5-------2
03-09-2004 05:01 AM
Thanks to all but I finally convinced the PBX tech that I was working with it was cabling. He gave in and I was able to help him with the pin outs and BAM! it came up.
Thxs to all
08-16-2005 11:54 PM
Would you happen to remember the pinout that worked on both ends?
08-17-2005 05:14 AM
Sorry I do not remeber off the top of my head.
THis might help
