Community Member
Controlling Multiple PRI T-1's with 1 d Channel
We are connecting a Redcom IGX to three Cisco 3745 routers (12.4(7g) ios) with 13 T-1's using MGCP and a Call manager running 4.1. We just converted to PRI using 4ESS between the two. The redcom has a way to control (span) up to 5 T-1's using one D Channel, is it possible to control (span) multiple T-1's using one D Channel on the call manager?
Re: Controlling Multiple PRI T-1's with 1 d Channel
as far as I know, this is not possible.
Protocols like NFAS, R2 and QSIG can not be used on MGCP controlled gateways.
Hall of Fame Super Red
Hi Justin,
Teodor is correct here (nice one T!) NFAS is only currently supported with h.323 not MGCP.
Here is a Cisco note indicating this as well as a couple of config docs;
From Esteban @ Cisco;
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K10070486
From Milan;
http://www.cisco.com/warp/public/793/access_dial/quadt1_nfas.html
From Chris;
Hope this helps!
Rob
297
