COR on VG224
j.mccartney
Hi all,
Can you place a COR on a VG224 to restrict inbound calls to a modem or group of modems.anyone have a basic cfg on how to do this?
Thanks.
fmeetz
Level 4
Level 4
Yes we could use COR to restrict the calls.
Do you have a cfg I could look at to get an idea.
Thanks.
Thanks for the information, I think I have configured the solution I was looking for. Does anyone know if there is a way to assign DN's from CCM through the VG224 and have it go out thru POTS lines? Right now it appears they are going out the PRI's we have.
Right now I have cfg'd the VG to use MGCP through partitions/CSS to block inbound calls and allow outbound only.
Thanks again to all.
