CUCME 8.6 Call not forwarding Voicemail
Hi frieds,
     In our office we are using  CUCME 8.6 on Cisco 2951 and unity express 8.5 in ISM module. As per our configuration  whenever user is busy or not answering , the call will forward to voicemail. Totally we have 24 PSTN line. So we have an additional gateway 2901. The Issue I’m facing is that, when a PSTN incoming call coming through the second gateway(2901), if the extension is busy or not answering the call is disconnecting instead of forwarding to voicemail.
My 2951 configurations
voice service voip
ip address trusted list
ipv4 172.16.19.80
ipv4 172.16.19.81
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
registrar server.
Dial peer we are using for voice mail:
dial-peer voice 99 voip
destination-pattern 1099
session protocol sipv2
session target ipv4:172.16.19.81
dtmf-relay sip-notify
codec g711ulaw
no vad.
2901 Configurations
voice service voip
  ipv4 172.16.19.80
  ipv4 172.16.19.81
  ipv4 172.16.19.82
codec g711ulaw
no vad
Debug CCSIP Calls
Dec 15 15:23:23.448: //37497/8FD56BBAA9EA/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0xAF40FD8
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           : 5000
Called Number            : 1099
Source IP Address (Sig  ): 172.16.19.80
Destn SIP Req Addr:Port  :
Destn SIP Resp Addr:Port :
Destination Name         :
Dec 15 15:23:23.448: //37497/8FD56BBAA9EA/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 172.16.19.80
Source IP Port    (Media): 25364
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 47
Disconnect Cause (SIP)   : 200
For your reference I here attach a network diagram
What the command which I missed?
1 REPLY
Re: CUCME 8.6 Call not forwarding Voicemail
Check License status on your CUE, I had same issue.. Finally figured out its about license.. sh license status
1046
