Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
default dial peer
How an default dial peer 0 can be modified and used,in what way it is useful.
1 REPLY
Re: default dial peer
you can't change the 'default dial peer' as Dial peer 0 is hard coded into IOS. You can nominate another dial peer to act as the default dial peer using the system cli -
dial-peer voice 1111 voip system
incoming called-number .
codec g711ulaw
dtmf-relay h245-alphanumeric
This allows you to change the default characteristics of the voice calls as specified on the configured dial peer.
240
