dial peer problem
I config the dial-peer to receive incoming traffic. However the call cannot be coome in. The "out stat" is down. How to solve it?
rdgs.
R1 config
dial-peer voice 86601 pots
description from CA
destination-pattern 000.
direct-inward-dial
port 6/0:D
dial-peer voice 86602 pots
description from CB
direct-inward-dial
port 6/1:D
R1#sh dial-p v s
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT
86601 pots up up 000. 0 down 6/0:D
86602 pots up up 000. 0 down 6/1:D
1 REPLY
Hall of Fame Super Gold
Re: dial peer problem
Is the port up ? Check show isdn status. Also see:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010e6d1.shtml
note: your DPs are missing "incoming called number ." to activate "direct-inward-dial".
169
