DIAL PLAN PROBLEM
Hello All,
I am trying to dial out from my VOIP phone using my PSTN at home. I am able to route calls in to the VOIP phone with no problem after entering "connection plar 5003" Command. When I attempt to use the commands below I get a busy signal. I think my CME is not recognizing the dial plan I configured.
dial-peer voice 1 pots
destination-pattern [770]..[...]....
port 1/0/0
I have tried
destination-pattern 9[770]..[...]....
and
destination-pattern ..........
also what is the right command to dial long distance?
Re: DIAL PLAN PROBLEM
A few things to note:
1) on a pots dial peer, any time the digit is explicitly matched, it is dropped.
so pattern 9....
would only send ....
but
pattern (9).... or [19]....
would both send 5 digits.
This is changed with:
forward-digits | all
no digit-strip
changing the destination pattern.
Also:
the [xxx] parameter is an OR operation. What your current destination pattern says is:
7 OR 7 OR 0 followed by two numbers, followed by ANY NUMBER or ANY NUMBER or ANY NUMBER followed by 4 more numbers.
You probably want something like this:
9770.......
forward-digits 10
This will send 770 plus 7 digits. If you need to dial one, add a 1 in the pattern and forward-digits to 11.
Alternatively:
9(1770).......
-nick
Thanks Nick I will let you know i fthis works for me. The CCNA Voice book realy confused me.
Hello Nick,
I think everything you told me worked. Please pay no attention to that last email I sent. It was all my fault. Thanks Man
Glad I could help :)
-nick
161
