Disconnect problem with FXO modules
We all know about disconnect problem, which has been with FXO modules for 1700, 2600 and 3600 routers. But i heard that Cisco solved this problem with their new IOS realese for 2600.
Does anybody know version of IOS for 1751-V, that could solve this problem?
Silver
Re: Disconnect problem with FXO modules
Yes - the 1751 has this feature. If you load later 12.2T code you will see the command 'supervisory disconnect ...' under the voice port config -
http://www.cisco.com/warp/public/788/signalling/fxo_disconnect.html
test
Thank you very much for such good answer.
What exact IOS do you think will be the best solution?
I need to have FR functions as 1751V is used like router for local office.
I dont sure of exact IOS name, if you know - tell me please...
Silver
if you have enough DRAM and flash, use 12.2.15T10 and IP Voice feature set.
724
