Does Cisco 2911 voice routers work with cisco SPA 514G phones
We want to deploy a Cisco 2911 voice router but looking for cheap phones with two Giga bit ethernet ports (one to the switch and the other to computer)  that has a display and user friendly. I want to know if the cisco SPA 514G will work with it?
Everyone's tags (6)
SPA500 phones are supported in UC500.
Hope to help, please remember to rate the post if it does.
Kind regards,
- Adrian.
Re: Does Cisco 2911 voice routers work with cisco SPA 514G phone
On CME, SPA5xx are only supported as 3party phones. So several services (local directory e.g.) are not supported without some workaround.
Norbert
I am having "Error: spcp
I am having "Error: spcp register token rejected 514G"
I am trying to provision 3 spa514G phones to Cisco UC540 with CME. However I am unable to have them registered.
I have a spa508G that works fine, as there seems to be loads for spa50X versions, not for spa51x.
Please advice, I downloaded the .bin file for spa51x, however, when I run the telephony service > load 514G firmware, it does not work, if I use load ? >> it lists a bunch of devices but it does not list the 514G
1215
