Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
DSP farm & Voice adaptor
we have a cisco router 7206VXR (NPE225) processor with VXC-2TE1+ Port adapter, 2 ports installed for
voice calls.
I can see the following configuration in the router. where is the DSP module inserted? is it inbuilt
with VXC-2TE1+ Port adapter or separately we need to install in the simm module in the router?
I can see only one DSPfarm1/0. why DSPfarm 1/1 is not showing ?
Suppose i replace the existing VXC-2TE1+ Port adapter should i change DSP configs as well?
dspint DSPfarm1/0
codec high ecan-extended
shut 0,6
controller E1 1/0
pri-group timeslots 1-16
controller E1 1/1
pri-group timeslots 1-31
interface Serial1/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-qsig
isdn protocol-emulate network
isdn incoming-voice voice
isdn T310 40000
isdn contiguous-bchan
no cdp enable
interface Serial1/1:15
no ip address
encapsulation hdlc
isdn T310 60000
no cdp enable
voice-port 1/0:15
input gain 6
output attenuation -1
echo-cancel coverage 32
voice-port 1/1:15
input gain 7
output attenuation 3
echo-cancel coverage 24
echo-cancel mode 2
music-threshold -50
1 REPLY
Bronze
Re: DSP farm & Voice adaptor
The DSPs are necessary for packet telephony technologies such as Voice over IP (VoIP), Voice over Frame-Relay (VoFR), and Voice over ATM (VoATM). The DSPs are responsible for the conversion of voice from analog to digital forms and the other way around, to set the gain and attenuation parameters, for the operation of Voice Activity Detection (VAD), and more. Proper hardware and software operation of the DSPs is necessary to ensure that calls can be established and maintained correctly. The below URL also includes discussion of how to identify and troubleshoot the DSPs which are used by the PA-MCX MIX-enabled Multichannel T1/E1 Port Adaptors for the Cisco 7200 router platform, when these voice-capable Port Adaptors are used for voice termination. When used for voice termination, the PA-MCX T1/E1 Port Adaptors dynamically obtain DSP resources from a PA-VXA/PA-VXB/PA-VXC Voice Port Adaptor installed on the same Cisco 7200 router.
http://www.cisco.com/en/US/products/hw/routers/ps341/products_tech_note09186a008019f2fa.shtml
264
