E1 is up , but no calls ,how you test it
I have an E1 in my 3845 , is up
contrlloer is up , but when I do
csim start command , its gave me this MSG
"csim err:csim_do_test Error peer not found"
so how to test my E1 calls ,and find out if the problem from Service provider or me?
i checked with Service provider and they informed me that everything is fine.
controller E1 0/1/1
framing NO-CRC4
clock source line primary
pri-group timeslots 1-31
dial-peer voice 2 pots
destination-pattern 339T
direct-inward-dial
port 0/1/1:15
thanks
  • Voice over IP
Hall of Fame Super Gold
Re: E1 is up , but no calls ,how you test it
You need dial-peer configured, are you familair with voice setup on cisco >
this is my config & some debug
note:I change the port ,and the cables
same result
controller E1 0/1/0
framing NO-CRC4
dial-peer voice 1 pots
destination-pattern .T
direct-inward-dial
port 0/1/0:15
voice-port 0/1/0:15
dial-peer voice 200 voip
max-conn 30
voice-class codec 100
session protocol sipv2
incoming called-number .T
csim start 31225549
csim: called number =31225549, loop count = 1 ping count = 0
Show controller E1 0/1/0
E1 0/1/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20071129, FPGA: 20, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (549 seconds elapsed):
985 Line Code Violations, 8195 Path Code Violations
71 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
71 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 91 Unavail Secs
Data in Interval 1:
987 Line Code Violations, 46 Path Code Violations
36 Slip Secs, 0 Fr Loss Secs, 35 Line Err Secs, 0 Degraded Mins
55 Errored Secs, 0 Bursty Err Secs, 9 Severely Err Secs, 671 Unavail Secs
Total Data (last 1 15 minute intervals):
987 Line Code Violations, 46 Path Code Violations,
36 Slip Secs, 0 Fr Loss Secs, 35 Line Err Secs, 0 Degraded Mins,
debug isdn q921 is ON.
Router#
*Apr 27 12:13:32.867: ISDN Se0/1/0:15 Q921: L2_EstablishDataLink: sending SABME
*Apr 27 12:13:32.867: ISDN Se0/1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Apr 27 12:13:33.867: ISDN Se0/1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Apr 27 12:13:34.867: ISDN Se0/1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Apr 27 12:13:35.867: ISDN Se0/1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Apr 27 12:13:41.867: ISDN Se0/1/0:15 Q921: L2_EstablishDataLink: sending SABME
*Apr 27 12:13:41.867: ISDN Se0/1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Apr 27 12:13:42.867: ISDN Se0/1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Apr 27 12:13:43.867: ISDN Se0/1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Apr 27 12:13:44.867: ISDN Se0/1/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
debug isdn q931 is ON.
Router#
*Apr 27 12:14:57.867: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*Apr 27 12:15:06.867: ISDN Se0/1/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
debug isdn event is ON.
*Apr 27 12:21:38.867: ISDN Se0/1/0:15 EVENT: Pri_Activate_L2: sending NL_EST_REQ
*Apr 27 12:21:42.867: ISDN Se0/1/0:15 EVENT: CCPRI_Go: received NL_REL_IND
*Apr 27 12:21:47.867: ISDN Se0/1/0:15 EVENT: Pri_Activate_L2: sending NL_EST_REQ
*Apr 27 12:21:51.867: ISDN Se0/1/0:15 EVENT: CCPRI_Go: received NL_REL_IND
*Apr 27 12:21:56.867: ISDN Se0/1/0:15 EVENT: Pri_Activate_L2: sending NL_EST_REQ
*Apr 27 12:22:00.867: ISDN Se0/1/0:15 EVENT: CCPRI_Go: received NL_REL_IND
*Apr 27 12:22:05.867: ISDN Se0/1/0:15 EVENT: Pri_Activate_L2: sending NL_EST_REQ
Your E1 is down. It may be a cabling problem, or perhaps the circuit is using CRC4.
how you know that?
plus I want to be sure where is the problem exactly?
if you need any debug plz tell me?
Thanks alot & appreciate your help
See all the errors in show controllers E1, these have to go away for the circuit to work.
You don't need any debug, just correct configuarion and cabling.
After thta, if still doesn;t work, it's SP resposnabiity to fix, even if they say it's ok.
2392
