E1
worldcalltel
Objective: Configure the E1 with the following framing and line coding. Check the status of each port.
Req'd:
Framing: NO-CRC
Line Coding: CAS / HDB3
Config:
Router(config)#controllers e1 1/0
Router(config-controller)#no framing crc4
Router(config-controller)#linecode hdb3
Router(config-controller)#clock source line primary
Router(config-controller)#cas-group 1 timeslots 1-31 type r2-digital r2-compelled ani
Router(config-controller)#cas-custom 1
I'm using 3745 Cisco Router and setting up a 4 E1 ports to be open. My provider gave me the specs above, to configure. After i done this. We run some test, unfortunately the test was a failure. When issue the command show controller E1, the ports were down. I also check the voiceport, show voice port, the in and out status were idle and operation is down. My question is how do i resolve this problem? what possibly cause this? is there anything wrong with my config?
Thnks.Kindly notify me as soon as possible
7 Replies 7
amit.pandit
What exactly are you getting when you do
sh controller e1 ??
Could you upload the e1 config? (Use sh run and copy from there)
-AP
E1 1/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20040408, FPGA: 11, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 0.
Data in current interval (682 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
657 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
657 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 81 15 minute intervals):
0 Line Code Violations, 2 Path Code Violations,
70005 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
70006 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
The ports was up now. follow up question.
When i test the call, everytime i monitor the calls, it shows "no circuit available". i try using the debug commands but no logs were displayed. what is wrong with this?i can't figure it out (it is obvious that my port were up, how come i got an error message no ciruit?). the provider said that the trunks were already open. but i can't make a call.
to answer your questions without the relevant parts of your config is impossible. So can you please post your E1 controller config and the voice config (cut out security related things like passwords and the like).
Regards, Martin
GlobalTelwise3745#sho run
Building configuration...
Current configuration : 3057 bytes
version 12.3
service password-encryption
hostname GlobalTelwise3745
boot-start-marker
boot-end-marker
enable secret xxxx
username NOC password xxx
network-clock-participate slot 1
network-clock-participate slot 3
voice-card 1
dspfarm
voice-card 3
dspfarm
no aaa new-model
ip subnet-zero
ip cef
voice class codec 1
codec preference 1 g729br8
codec preference 2 g729r8
codec preference 3 g723ar63
codec preference 4 g723r63
codec preference 5 g723ar53
codec preference 6 g723r53
controller E1 1/0
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled
cas-custom 1
controller E1 1/1
framing NO-CRC4
cas-custom 1
controller E1 3/0
framing NO-CRC4
cas-custom 1
controller E1 3/1
framing NO-CRC4
cas-custom 1
interface FastEthernet0/0
description Connection to LAN
ip address 210.x.77.x.255.255.252
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip id vm20 ipaddr 62.192.173.60 1718
h323-gateway voip h323-id TelwisePLDT
interface FastEthernet0/1
no ip address
duplex auto
speed auto
ip default-gateway 210.5.77.10
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 210.5.77.17
voice-port 1/0:1
input gain 6
echo-cancel coverage 32
bearer-cap Speech
voice-port 1/1:1
input gain 6
bearer-cap Speech
voice-port 3/0:1
voice-port 3/1:1
dial-peer voice 100 pots
description testing
destination-pattern 2503T
port 1/1:1
prefix 632
banner motd ^C
Warning!Authorized users only. ^C
alias exec active sh call act voi br
alias exec u undebug all
alias exec act sh call act voi br
alias exec sum sh voi port sum
alias exec ip sh call act voi br | include ip
alias exec histip sh call hist voi br | include ip
alias exec calls sh call res voi st
alias exec hist sh call hist voi br 5
alias exec scb show call active voice brief
alias exec sc show call active voice
alias exec sch show call history voice brief
alias exec sd show dial-peer voice sum
alias exec sv show voice port summary
alias exec ro show rtr op
alias exec dsip debug ccsip all
alias exec connections sh voip rtp connections
alias exec lastcall sh call hist voice last 1
line con 0
password xxx
login
transport preferred all
transport output all
speed 38400
line aux 0
line vty 0 4
password xxx
login
transport input all
end
I'm getting cause 500-Internal Server Error and cause 34-no circuit. When i try to test a call using sip i see logs of my last call, but when try using h323 i see none. My point is what could be the reason why can't i make a calls. All the framings and line codings specified by our provider (hdb3, r2 signalling, no crc) are already specified in my config.
So you have Slip Secs...
I'm thinking if you need this command: network-clock-select
its no use. im still getting no circuit error. what else? and i issue a command show voice port summary, it shows
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
1/0:1 18 r2-digital up up seized idle y
Does it mean that our provider is blocking our calls?
I had issues with R2 that cleared up when rebooting. Turned out - IOS bug.
