Community Member
Edge router for VOIP
What router is recommended for VOIP? We currently have a 7206vxr NPE300 connected to a Nextone SBC. However, the 7206 cpu is running at 98% with only 17 DS1's woth of traffic. Do we need to upgrade?
Hall of Fame Super Gold
Re: Edge router for VOIP
can you clarify ? What voice features are running on the npe300 ? What interface are you using and what is the data traffic on them ?
Community Member
we are running g711 on the npe300 interfaced with a GigE pa-ge and the traffic is all voip and fax
Community Member
I forgot to add, that we have a 2gig internet connection coming in to our 3500 and then connects to our 7206 via the pa-ge.
Community Member
Any other suggestions?
Marvin
Community Member
We removed the bridge-group 1 command from our GigE interface and the CPU usage dropped by 50%.
342
