Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Error when trying to configure QOS on interface
Folks,
I received this error when trying to configure service policy out from interface.
Router(config)#int fa3/4
Router(config-if)#service-policy output SETDSCP
QoS: FastEthernet3/4 doesn't support policy SETDSCP for class VOICE in Out direction
router(config-if)#
Re: Error when trying to configure QOS on interface
Can you share the class-map and policy-map config?
This message is thrown if the policy is not supported in out direction.
Can you let us know which platform it is?. Also it would be better if you can paste the policy-map, class-map config.
Nagendra
Could be related to this -
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/qos.html#wp1720400
Policers can act on ingress traffic per-port or per-VLAN. With a PFC3, for egress traffic, the policers can act per-VLAN only
You will have to give us a bit more information about platform/IOS versions etc ... if you want a more detailed answer.
187
