Expanding E1 for AS5400
I'm currently having Cisco AS5400 as the voice gateway for my system. The gateway will terminate the 2 lower layers of the ss7 stack and encapsulates into RUDP packets and sends to Cisco PGW2200. The signalling will then be backhauled back to the gateway as ISDN PRI. So my question is i'm i want to add another E1 interface card on the gateway (to the same APC/DPC), can I use the same nfas group? And is there a limit on how many timeslots that can be used for ISDN backhaul from PGW?
Everyone's tags (2)
Hall of Fame Super Gold
wrong forum, try "Service provider - voip". You can move the post using the control panel on the right.
Thanks. Question moved to the said discussion.
806
