11-05-2007 02:01 PM
I have one DN (7405) I can assign it to any device without error, but when I dial it assigned or not I get a fast busy. I have deleted it from the unused DN group, removed the phone, placed it on others with the same result. What am I missing?
11-06-2007 04:08 AM
- Use DNA to analyze how the call flow is running (https://ip/dna)
- turn on CCM traces (assuming u re using Callmanager)
- do CFwdA from that DN to any other DNs, call 7405 and check it will forward to the other DNs.
11-08-2007 06:36 AM
Well, since my post another process required me to reboot the call managers. Whatever was going on that has cleared out and the DN is working now. I don't see that as a solution, but I guess I'll just have to wait and see if it happens again. Thanks for the advice anyway. Oh the URL you provided does not appear to work. What is it?
11-11-2007 06:37 AM
What version of CCM Are you running? (exact version)
11-11-2007 10:58 AM
4.1(3) sr5b
11-11-2007 01:41 PM
You are likely hitting a known issue that will likely be fixed in the next SR. It occurs when phones are deleted that have CF/CFA setting on.
A restart of the CCM Service is required to clear the entry from memory.
You can also try removing your CallForward settings before deleting the phone.
11-11-2007 08:25 PM
Not sure about the setting before. I know the DN was on two phones in two different partitions. (oops) I changed them to the same partition making a shared line and the problem continued. I removed both of them and got the same result. I think I will try to reproduce this condition and see what happens. Thanks.
11-12-2007 05:21 AM
Interesting. I have not attempted to reproduce this, so I can't confirm exactly what circumstances might cause it. But look for it to be fixed in the next SR.
