Fax Off-Ramp : FXO Problem
I'm actually configuring Fax off-Ramp on a Router 2811.
It's working fine with an ISDN connection (Modulo 2 BRI), but it's not working with an analogic line(Modulo FXO)
on the router, i have this message during the transfer, after approximatively 30 sec. :
%LAPP_OFF-6-LAPP_OFF_CAUSE_ABNORMAL: Call aborted (cause = 0x13)
The Analogic line works fine, because I have test it with Call, and with fax on-ramp too
Are they some restrictions for Fax off-Ramp with Analogic connection?
Thanks in advance for your help,
Baptiste
Re: Fax Off-Ramp : FXO Problem
These error messages are reported every time FAX disconnect cause code is not "Normal call clearing" (ie 0x16).No Action is needed in this case. Refer URL
http://www.cisco.com/en/US/customer/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a0080080b67.html#wp1085944
Hi Baptiste,
I have exactly the same problem with you. Did you find a way to solve this problem?
I would be very appreciated if you can help me..
nehir
366
