fax-relay problem at MC3810
i can not send fax messages from Mc3810 (IOS 12.0(6r)T4). I tried to change the input gain ang output attenuation but no effect. The dial-peer have the following configuration:
dial-peer voice 700 voip
destination-pattern 7095.......
session target ipv4:xxx.xxx.xxx.xxx
tech-prefix 011#
dtmf-relay cisco-rtp
fax protocol t38 ls-redundancy 5 hs-redundancy 2
ip precedence 5
no vad
Can you give me a pice of advice ?
1 REPLY
Silver
Re: fax-relay problem at MC3810
Have you seen any error messages. If not try changing the fax machines and see if it works to rule out interoperability issues. You could also use the "fax rate disable" command to disable fax translate.
126
